was there any difference in camber on different years of I beams?
will the i beams from a 2wd f250 fits in a f150?
will the pre 80's i beams fit in the early 80's trucks?
Thanks, got a couple ideas brewing but need these questions answered
80+ are the same, and 79 and older interchange, but with the 80 model year they moved the steering from behind the axle centerline to in front of it, so you cannot swap between 70s and 80s. The I-beams of each style can be swapped around into any frame of the era they fit, you can put beams from a 79 F350 into a 65 F100, or ones from an 80 F100 into a 96 F-whatever. It all swaps.
__________________
Jared
The government said all my vehicle were too old to be clunkers
I too work construction. Concrete Construction, usually early in the process. IE: sites are very crude, and rough. Worse after We get done with them. 80K concrete mixers tend to rut things up pretty bad. I hardly ever use 4X4
__________________
93 F One Fiddy- 5.0/AOD/3.55 230K OEM
93 F Two Fiddy Scab- 7.3/ZF5/3.55/Sidewinder II,94 Turbo pump,G Inj's, Velvet Ride, Ride Rite Rear, Turbo Bumper, Alcoa's
85 F Two Fiddy-6.9/C6/3.54/ Holley Red, Racor, Soup Bowl,AutoJet 3",Ride Rite Rear
