1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
how to Change a door ajar switch
Old 10-20-2009, 11:13 PM
cfd312's Avatar
cfd312
cfd312 is offline
How do you change out the door ajar switch on a 2004 F350 extended cab? Drivers door. I have tried to WD40 trick with no luck. Thanks for the tips for that. Would anyone have laid out instructions on how to remove and install the new switch.
Thanks
Old 10-21-2009, 05:09 PM
ameinig's Avatar
ameinig
ameinig is offline
The switch is installed in the door latch assembly inside of both front doors. It actually comes out with a quarter turn and disconnecting the wire harness. There isn't really anything to keep it from coming out without removing the latch assembly from the door, but I couldn't get a good enough grip on the switch to turn it out. It is in a weird spot at an angle off of the latch so you have to contort your arm up inside the door. The latches aren't hard to remove, it is just a PITA to work inside the door. I don't remember the switches themselves being very expensive. I replaced mine about two years ago and have not had a problem with the door ajar light since.
Old 10-22-2009, 05:00 PM
cfd312's Avatar
cfd312
cfd312 is offline
Thanks for the help. Got the new switch for $15 and had it changed out in 20min. Go figure the dealership ship was going to charge $100(estimated) of course. Yeah right. Anyway thanks for the help.
Gotta love FTE
Old 10-22-2009, 08:41 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,097 Likes on 997 Posts
Now you have saved enough to be able to afford to join FTE as a SUPPORTER. You DO get tired of seeing all those ads on every page don't you? Support FTE and get rid of them.
Old 10-22-2009, 11:56 PM
ameinig's Avatar
ameinig
ameinig is offline
No problem. Your arms must be more limber than mine, I couldn't get the switch out without pulling the latches!
Old 06-10-2023, 08:12 PM
up4change's Avatar
up4change
up4change is offline
1st Gear
I have a 98 F150 XLT super cab Heritage. 3door issue w wiring harness
switch is installed in door latch assembly inside both front doors. It is weird I replaced harness and have problem with pass door ajar wiring has 2 door ajar connectors whereas my original Door only has 1 connector with 1 DoorAjar
i’m not an expert when it comes to wiring/electrical and have a harness that has 2 door ajar connectors, and my originally has ajar connector
so my question
how do I disconnect 1 of 2 connectors? or try to install 2 door ajar switches for passenger door
I’m not experienced in electrical if I need to provide photos, please feel free to reply, and I will certainly take photos of what I have because I have them removed the majority of the electrical tape on the harness. Thank you.
AVR2
Electrical Systems/Wiring
04-19-2016 05:26 PM
artieb
03-30-2016 11:51 AM
ripee78
11-05-2015 12:13 AM
rpstrong
12-13-2013 06:47 PM
afonda
25
06-15-2012 12:33 AM
Quick Reply: how to Change a door ajar switch
