how to Change a door ajar switch - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-21-2009, 12:13 AM
cfd312 cfd312 is offline
cfd312 is starting off with a positive reputation.
How do you change out the door ajar switch on a 2004 F350 extended cab? Drivers door. I have tried to WD40 trick with no luck. Thanks for the tips for that. Would anyone have laid out instructions on how to remove and install the new switch.
Thanks
Old 10-21-2009, 06:09 PM
ameinig ameinig is offline
ameinig is gaining momentum as a positive member of FTE.
The switch is installed in the door latch assembly inside of both front doors. It actually comes out with a quarter turn and disconnecting the wire harness. There isn't really anything to keep it from coming out without removing the latch assembly from the door, but I couldn't get a good enough grip on the switch to turn it out. It is in a weird spot at an angle off of the latch so you have to contort your arm up inside the door. The latches aren't hard to remove, it is just a PITA to work inside the door. I don't remember the switches themselves being very expensive. I replaced mine about two years ago and have not had a problem with the door ajar light since.
Old 10-22-2009, 06:00 PM
Thanks for the help. Got the new switch for $15 and had it changed out in 20min. Go figure the dealership ship was going to charge $100(estimated) of course. Yeah right. Anyway thanks for the help.
Gotta love FTE
Old 10-22-2009, 09:41 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Now you have saved enough to be able to afford to join FTE as a SUPPORTER. You DO get tired of seeing all those ads on every page don't you? Support FTE and get rid of them.
Old 10-23-2009, 12:56 AM
No problem. Your arms must be more limber than mine, I couldn't get the switch out without pulling the latches!
How do 2003-era "door ajar" switches work? AVR2 Electrical Systems/Wiring 0 04-19-2016 06:26 PM
Passenger Side door Ajar mattymax 1999 to 2016 Super Duty 6 12-17-2014 07:18 PM
97 Aerostar door ajar battery pull down trkayak Aerostar 6 10-13-2014 12:11 PM
dome light/door ajar socalarcade Ranger & B-Series 2 12-12-2010 06:17 PM
Extended Cab Door Ajar Light cfd312 1999 to 2016 Super Duty 6 10-01-2009 01:42 PM
Tags
1999, 2005, ajar, change, door, f150, f250, f350, ford, lincoln, mark, pic, switch, switches, truck, viii
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
