Resistance in rear ABS sensor
Old 10-20-2009, 09:50 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
BURNSTOUGHFORD is offline
I need to know what its supposed to be. I have an ABS light on right now and both front wheels are getting the same resistance as each other when spinning and sitting still. And my rear sensor has way more resistance than the front two and doesn't change with wheel speed.
I think it was 30-40k ohms.
Thanks for the help.
Old 10-21-2009, 08:45 AM
mikren's Avatar
mikren
mikren is offline
I remember testing my rear sensor and I beleive it had 1400 or 1500 ohms and did change slightly while spinning the wheels. The rear sensor is very cheap to purchase compared to the front.
Old 10-21-2009, 09:23 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Rear sensor should be around 1.5 k ohms
To dynamically test an ABS sensor, connect the meter leads to the sensor, set the meter to a low AC voltage scale, and spin the wheel. A good sensor will give several volts AC during this test.
Kyle Natoli
05-03-2017 08:43 PM
Jtsarby
04-01-2016 10:31 PM
beamundson
1997 - 2003 F150
03-28-2012 04:23 PM
zrt600guy
1983 - 2012 Ranger & B-Series
02-14-2012 04:10 PM
WilleyB
1999 to 2016 Super Duty
13
10-27-2009 10:27 PM
Quick Reply: Resistance in rear ABS sensor
