I know there are dozens of ways to outfit a F650/750... so I'm looking at a 2000 F750 with a Cat engine...The current owner who is the 2nd owner has limited knowledge about it. Is there a fairly easy way to find out what the truck came with, the owner is no help and I'm not in the mood to send over a mechanic, Its just not that big a deal but I'm curious about the engine HP and axles...etc... any ideas?
the engine should be a 3216 or 3316 i believe it is.HP figures are around 210. as far as axles, you would need the info off the "B" pillar warranty tag to decode what is in it.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
The engine horsepower is probably 210 and the axles depends on the gvw. In the USA trucks are spec'ed differently a F-750 around here would have a 33,000lb gvw and 12,000lb front axle and 21,000lb rear axle.
Because of the stupid 26,000lb gvw law in the USA you guys have trucks with light axles.
I bought the truck... figured a 2000 F750 with cat motor (43k miles)7/8 yd box pto and plow for $8500 was a steal no matter how i looked at it. found out the axles are 9k front and 21k rear. The motor seems to have tremendous power, but not crazy about the electronic trani... thanks
