1962 mercury F100
3 liters = 182 cubic inches.
How did you come up with that engine size? And...is it a 1966?
1961/65 trucks manufactured and sold in Canada only have a 15 digit VIN = example: 5991014L-123456A.
The engine size itself is not listed in the VIN, or on the Warranty Plate.
The first digit of the VIN decodes to either a 6 or V8. 1965 example: 5 = 6 cylinder engine.
There is a two letter code used for what size the engine is, listed separately on the plate = 1965 examples: SP = 240 I-6 / SQ = 300 I-6.
1966 and later trucks manufactured and sold in Canada only use the same 11 digit VIN system as 1961/80 US trucks = 1966 example: F10AC876543.
The 4th digit of the VIN is the engine code.
A = 240 cubic inch I-6 // B = 300 cubic inch I-6.
1961/64 223/262 I-6 engines: The intake & exhaust manifolds are on the LEFT (drivers) side of the engine.
1965 and later 240/300 I-6 engines: The intake & exhaust manifolds are on the RIGHT (passenger) side of the engine.
There is no such thing as a 3 liter 6 cylinder engine installed in any Ford truck...regardless of what year it is.
http://inlinethumb21.webshots.com/40...425x425Q85.jpg
http://inlinethumb59.webshots.com/43...425x425Q85.jpg
new for '64 on the F100/F250
self adjusting brakes
double wall box
single hand tailgate
longer wheelbase
262 six
sounds right to me
Um Bill how do you explain this FORD brochure, touting the NEWLY available 262 in an F100 in 1964 then?
double wall box
longer wheelbase
262 six
sounds right to me
double wall box
longer wheelbase
262 six
sounds right to me
How do you explain the 1957/63 truck parts catalog listings for engine/trans mounts and etc. for 1961/63 262 2WD/4WD's?
I've decoded several VIN's/Warranty Plates for 1961/63 F100/350's with 262's.
Sales brochures are not always correct. Do you have the 1957/63 Ford truck parts catalog?
3.7L = 223 I-6. This engine was not used after 1964 in any Ford truck or car.
1965/66's have either a 240 or 300 I-6. The exhaust/intake manifolds are on the RIGHT side of the engine.
Idiot (Warning) Lights for the Oil/Amp gauges were standard equipment on all 1961/66 Standard & Custom Cabs, except 1965/66 F100/250 Camper Specials which came with Oil/Amp gauges.
Oil/Amp gauges were optional on all other 1961/66 trucks.
btw: Ford did not begin to use liters to designate engine sizes on trucks/Bronco's/Econolines until 1981.
No, I don't have the parts Catalog. I don't need a manual to tell me the sun comes up in the morning.
But if I had one, and it said the sun comes up at noon, I guess that would be right.
If the exhaust/intake manifolds are on the LEFT side of the engine, your truck is not a 1966, or a 1965.
http://farm4.static.flickr.com/3582/...8ab921f22f.jpg
that's a 300 ci six, a 240 is very similar looking.
(unless the parts manual says otherwise)
Tnxweaver
10-17-2015 01:55 PM
coleman1962f100
08-24-2010 08:22 PM
no1lowr
1961 - 1963 F100 Unibody
10-20-2009 03:12 AM
John4796
08-03-2003 08:17 AM
