Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-26-2009, 01:22 PM
78 F150 78 F150 is offline
78 F150 is starting off with a positive reputation.
I'm not sure if these would work in mine as the retractor looks to be at the top. I'll try to get a pick up the belts in my truck.
  #17 (permalink)
Old 10-26-2009, 07:28 PM
ShamelessMT's Avatar
ShamelessMT ShamelessMT is offline
1976 Ford F-250
ShamelessMT is starting off with a positive reputation.
I just installed these AMSAFE Retractable Lap & Shoulder 105" No Shoulder Mount in my truck. Actually, I only installed the passenger belt, since it took more time than expected and that belt was in much worse shape.
I had to do a little creative thinking about how to get them in since they are not a direct fit. The assembly won't properly fit in the hole provided, plus if you mount them the same as the old ones the belt comes out in the wrong spot. That said, I had to remove the plastic housing around the spool of the new belt and then mount the spool upside down using the factory hole. The belt works perfectly fine this way, as far as I can tell, as it's a motion activated restraint - not a tilt activated mechanism like the original ones.
I'll take a picture when I'm putting the other one in this weekend so you can see what I mean. Maybe I'll get to it sooner, but no promises...
Btw, the cab of my truck is from a Regular Cab '77 F150, so it should be the same mounting as your '79 Regular Cab.
__________________
Sean
1976 F250 4X4 - Daily driver/tow rig/offroad toy
1977 Honda CB750F SS - Cafe racer/rat bike
  #18 (permalink)
Old 10-26-2009, 08:31 PM
i-w's Avatar
i-w i-w is offline
i-w is starting off with a positive reputation.
Pictures would be great!!!!
  #19 (permalink)
Old 10-26-2009, 10:27 PM
Quote:
Yeah, that would be great! And thanks for the info.
  #20 (permalink)
Old 11-08-2009, 02:04 AM
1976 Ford F-250
Ok, here it is. A week later than planned, but done and photographed as promised. I'll walk you through it...
First, go here: http://www.gotbelts.com/relapsh.html and buy 2 shoulder belts and 2 hardware kits.
First thing first - Remove the old seat belts. This is not as easy as it sounds. You'll need a big Torx drive (50) to remove the bolts and I had to go to at least 6 different stores before I found one here. The next problem is that the bolts won't want to come out, no matter how hard you crank on them or how much lube you use. I ended up cutting the 3 of 4 bolts off. This is where the hardware package comes in handy - you'll need the bolts and washers + the L brackets.
Stock Belt
Stock mechanism, notice it's bolted at the top.
When you get the seat belt mechanism out of the pocket in the wall of the cab you'll be left with this. One bolt hole above (stock belt used this one, the bolt has been cut off in this picture) and one below (this is the one you'll use).
Replacement seatbelt:
Before installing the new seatbelt, you'll need to remove it's black plastic covering so that it will fit in the hole (no big deal, it just pops off). Then mount the mechanism with the bolt at the bottom. Don't forget to use a big fender washer for rigidity and a lock washer with the bolt - all of this is supplied in the hardware kit. . This will make the seat belt come over the top, but if you try to put it in right side up you'll not get the belt through the hole on the factory cover.
New seat belt in place.
With cover on.
On the bottom end you'll need to use an L bracket from the hardware kit. This part is pretty self-explanatory, though I'd suggest you remove the plastic sheath from the old belt and use it on the new one (like I did).
One thing I discovered during this it that even though the new belt buckles are different than the stock ones, the belt will latch into the factory buckles. I don't really want to remove my seat to get to the other end of the belts, so I left them alone and buckle the new belt into the old buttons (hopefully that made sense).
All in all, it's not too bad, though it did take quite a bit more time than I expected due to stuck bolts.
Good luck. I hope this helps. Feel free to ask me any questions...
__________________
Sean
  #21 (permalink)
Old 11-11-2009, 12:13 AM
Man, thanks so much. I'm gonna order me a set and let u know how it goes. The pics are really helpful and thanks again!
Tags
1965 , 1978 , 1979 , back , belt , belts , f100 , ford , obsolete , parts , replacement , seat , seats , supercab , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
