Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-20-2009, 05:52 PM
06F150Guy 06F150Guy is offline
06F150Guy is starting off with a positive reputation.
Interior lights?
Ok this may seem like a dumb question but all my interior lights only work if I open the door or turn on the bed light! I cannot turn on the map lights or the dome light? I have an 06 xlt scab? Any suggestions?
__________________
2006 F150 XLT scab 5.4ltr 4x4:
Stock except: Billit Grill, Line X, K&N drop in, Stainless Tip, with more to come!
  #2 (permalink)
Old 10-20-2009, 11:58 PM
screwy's Avatar
screwy screwy is offline
Problem Developer
screwy is gaining momentum as a positive member of FTE. screwy is gaining momentum as a positive member of FTE.
Is your truck flex fuel?
__________________
2008 F-150 SuperCrew Lariat, 4x4, 5.4l, 3.73 LS
Previous Trucks:
2007 F-150 SuperCrew Lariat, 4x4, 5.4l, 3.73 LS
2001 F-150 SuperCrew Lariat, 4x4, 5.4l, 3.55 LS
1996 Bronco Eddie Bauer, 4x4, 5.8l, 3.55
1993 Bronco Eddie Bauer, 4x4, 5.8l, 3.55
  #3 (permalink)
Old 10-21-2009, 07:22 AM
sammer4u sammer4u is offline
sammer4u is starting off with a positive reputation.
Not sure what Flex Fuel has to do with it, but mine is an 06 XLT Scab Flex Fuel and map lights interior lights come on when I push them, with doors closed and cargo light off. Sounds like a wiring issue or something? Or the push lights are not making connections?
__________________
06 F150 XLT SCAB 4X4 5.4 FFV
Two tone Red/Silver
3.73 gears
6.5 Bed
Tonno Cover
Peak 3.5" Back up Camera/Monitor
  #4 (permalink)
Old 10-21-2009, 09:05 AM
hcbph hcbph is offline
2007 Ford F-150
My Garage
hcbph is starting off with a positive reputation.
Lights
I've for an 07 XLT and there's a pushbutton by each of the reading lights that will turn them on and off. In addition to that, there's a switch on the dome light that will turn that on. If your's doesn't then there may be a wiring issue involved. Good luck
  #5 (permalink)
Old 10-21-2009, 10:15 AM
I guess it must be wiring! Because all the switches work only when the door is open or I turn on the cargo lamp! I don't think it is a flex fuel? I bought it used back in March.
__________________
  #6 (permalink)
Old 10-21-2009, 02:34 PM
screwy's Avatar
Problem Developer
Quote:
Aye, I realize it seems odd, but in flex fuel vehicles the ac/dc converter for the gas gauge runs on the same power as the map lights. So here’s the deal, the circuit that runs the map lights is different then the one that runs the lights when the door is open, etc. Fuse 24 and the battery saver relay run the map light circuit. Id check that fuse, unfortunately the relay is supposedly un-removable, but I’ve never looked myself.
__________________
Previous Trucks:
  #7 (permalink)
Old 10-21-2009, 03:08 PM
How would I know if I have a Flexfiel? My wifes Impala has badging on her trunk but my truck doesn't!
__________________
  #8 (permalink)
Old 10-21-2009, 03:23 PM
There is a letter in the VIN number that designates it, plus on mine the gas cap states it.... If you have not seen it on the gas cap, then you do not have it!
__________________
Two tone Red/Silver
3.73 gears
6.5 Bed
Tonno Cover
  #9 (permalink)
Old 11-01-2009, 06:40 PM
Looks like it is the fuse! That number 24 is blown so I'll pick up a fuse tomorrow and replace it hopefully that is the issue! Thanks for your replies!
__________________
Tags
08 , 2004 , dome , f150 , ford , fuse , interior , lamps , light , lights , map , red , relay , turned , turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
