I trying to get all the fuel out of my rear tank as it has a bad leak and so i keep catching fuel in a container ( gallon every day ) and it was almost empty before the leak started and im solely running on the front tank yet I still have a gallon everyday does the front slowly fill the back too or what im really confused?
__________________ 1984 f250 6.9 idi diesel 4x4 with a borg warner t19 4 speed manual with a granny gear, 7.5" western unimount plow... ROLLIN' COAL!
'96 F350 crew cab XLT dually 2wd alcoa wheels 7.3 PSD E4OD ,300,000 miles+
64,999,987 firearms owners killed noone yesterday. protect our second amendment
1, The more likely scenario is that you leaking tank is not empty yet and evertime you drive you leak out more which spills all over the tank guard and drains to ground after you stop.
2, Your tank selector valve is not working right and directs return fuel to the wrong tank somehow. (possible, but less likely in my mind)
Normally the front and rear tanks are separate, assuming the tank selector valve operates the way it should and does not leak.
The best thing to do is just pull the leaking tank out completely. If you tank selector valve works you dont even need to plug the tank lines. I ran like that for several months after I removed my rear tank when it leaked. I had to pull the tank as it just kept leaking as it never really completely emptied out.
Seb.
Seb...
I think ill just go ahead and pull it cause my selector is in working order I almost positive and its really startin to make a mess
Crap, I have that same problem then. I KNOW my back tank is empty, and yet, at times, it drips fuel right from where the lines go into the tank. Strange though; it doesn't do it all the time, and I haven't used my back tank in about a year.
__________________
1992 2WD F-250 SuperCab 7.3L ZF5-spd, 4.10 rear. Rotella-T Full Synthetic, Royal Purple Full Syn ATF in ZF5 & Syn in Diff. Banks "Stinger" Air intake & Y-Pipe w/New custom 3" Stainless exhaust. Cooper ATR tires @ 70PSI w/nitrogen. All new brakelines, & clutch hyd. 78K on Jasper longblock - (207K on truck). Viton Injector O-rings. Just installed a Tommy-Lift liftgate. Now on to tackling Biodiesel production.
exactly my problem!!!!
