Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-20-2009, 12:17 PM
RynL88's Avatar
RynL88 RynL88 is offline
RynL88 is starting off with a positive reputation.
15 sec. crank after sitting
Hey guys.. got a couple questions here
our 04 developed a very long crank time yesterday.. 15 sec of continuos cranking after sitting 15 min or longer... less than that.. starts right up.
while on a delivery yesterday while enroute i got a "check guages" warning
looked around and found no oil pressure on the "guage".. this while at idle going down hill
step on accelerator and get above 1000 rpms.. oil press shows normal
while truck sat during delivery, very hard to get started.. all of the sudden.. never had this problem before?
hasnt' fixed itself yet...
changed both fuel filters, and looked for crud in hfcm... all looks good
thinkin its an oil problem..
can the low pressure system cause problems in hpop system?
i pulled oil filter out this morning and it was dry... i mean not dripping a drop of oil after it sat overnight.
i played with drain valve...in filter housing.. dunno how to tell if it is working
right or not?
could these two probs be related.. or is it most likely a coincidence and i have hpop leak somwhere
oh and it starts the same whether it sits for 15min or 2hours or overnight
only starts normally if sitting for less than 15 min- hot or cold
__________________
2006 F250XLT, CC, LWB, FX4, 6.0, auto. stock
2004 F350Lariat DRW 6.0 auto, 9ft alum. flatbed
1995 F250, 7.3, 5spd 286,000mi, TS 6 pos chip, Autometer guages, Tymar Downpipe & intake, 4 inch straight exhaust into 3" duals. Gutted EBPV, 1.0 Housing, Luk clutch and SMFW
  #2 (permalink)
Old 10-20-2009, 01:00 PM
fordboy2 fordboy2 is offline
fordboy2 is starting off with a positive reputation.
this is a guess I wonder if the oil is draining back out of the housing
__________________
06 f350 lariat srw-factory 20's(winter), mb shakers w/35" toyo mt's(summer), chrome package,zoodad, pioneer D3 with rear monitor,riderite air bags, sky jacker leveling kit, air lift air bags in front, 8.2 Boss v-plow, 90 watt corner strobes, 4" magnaflow turbo back exhaust minus the kitty, K&N fipk, coming soon spartan tunes, analog gauges
96 f350 reg cab lb, 7.3 auto 191000miles just gettin started
  #3 (permalink)
Old 10-20-2009, 01:54 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
2001 Ford Excursion
Toreador_Diesel has a good reputation on FTE. Toreador_Diesel has a good reputation on FTE.
Sounds like one of your HPOP branch tube developed a leak. Low or no oil pressure point directly to that.
__________________
If you live in Texas and need help with your truck, PM me.
FTE Excursion Forum Mod
Death Row Inmate #21
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
4 in. MBRP
AT 4040
HPX
Sonnax/Tricum Kit
'04 TT Mirrors
6' PROcomp lift
35' BFGs
Bosch HIDs
4.10 Gears
WW
Walbro GSL392
  #4 (permalink)
Old 10-20-2009, 02:43 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Old-Timer
BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all BPofMD is a name known to all
What brand oil filter are you using?
__________________
BPofMD - Bud
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB CrewCab Arizona Beige
2007 Arctic Fox 30' Fifth Wheel - 1997 Lincoln Mark VIII LSC
Join the Maryland Chapter click HERE
  #5 (permalink)
Old 10-21-2009, 07:59 AM
RynL88's Avatar
truck came with oil filter that is attached to lid. Replaced with another like that from napa.. I have read about why motorcraft filters should be used and am going to switch out the cap from my 06 w/ a new filter and see what happens.
then will pressure test hpop system
just wierd how these two seperate issues occurred at exactly same time
anyone heard of a "plug" inside hpop dislodging that seperates low pressure system from high pressure resevoir? Heard this was fairly common on 03-04 model years
__________________
  #6 (permalink)
Old 10-21-2009, 08:04 AM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
it could be a sticking ipr valve.the low oil pressure pump could be sticking in the housing or you could had a high pressure pump thats going out.if your hpop has a aluminum cover then you have a stc fitting that could be blown out.if its a cast steel then it would be the pump.need to get a scanner on the truck and see what codes you have and see what the actual icp pressure is.
__________________
ASE MASTER TECH FORD SENIOR MASTER TECH
  #7 (permalink)
Old 10-28-2009, 09:46 PM
RynL88's Avatar
truck fixed
just wanted to finish the thread
truck is all fixed
cause of long crank.. the bb in the dr. side of the hpop blew out causing open low pressure oil system..this also drained the entire low pressure oil galley on top the motor including oil filter housing when engine off.
pulled hpop, tapped the open hole with 1/8npt and plugged it
restart.. truck runs good.. good oil pressure at idle.. seemed low on power
take it out for a spin... steadily loses power unitl dead..about 20 min of driving
checked hpop pressure with autoenginuity... wont build over 350 cranking
check hpop system behind hpop with 150psi air.. no leaks
replace ipr.. no change
replace hpop.. problem solved.. however it has that darn bb in the side that blew out in the old one.. wonder how long it will last
after all this.. thinking maybe high pressure pump started to fail and caused an excess of pressure in low pressure system? causing that bb to blow out.
or the 30 miles it got driven back home after bb blew out ate up the hpop
or... just a neat little coincidence.
hope this helps someone in the future
thanks to all who replied!
__________________
  #8 (permalink)
Old 10-28-2009, 10:08 PM
bismic's Avatar
bismic bismic is offline
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
Glad you found the "root" of the problem.
Many aftermarket filters will not be long enough to keep the oil drain valve from allowing oil in the filter housing to drain back to the pan.
It is always possible that these aftermarket filters will allow oil to flow back to the pan and could prevent oil pressure from building. But mostly it is a cause of poor filtration.
Good idea to switch back to Ford, Racor, or International brand oil filter.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
  #9 (permalink)
Old 10-29-2009, 10:07 AM
2001 Ford Excursion
Quote:
What he said....
__________________
2001 X PSD Limited
6637 Filter
203* Thermo
SCT X-Cal2
4 in. MBRP
AT 4040
HPX
Sonnax/Tricum Kit
'04 TT Mirrors
6' PROcomp lift
35' BFGs
Bosch HIDs
4.10 Gears
WW
Walbro GSL392
  #10 (permalink)
Old 10-29-2009, 10:09 AM
gearloose1 gearloose1 is offline
gearloose1 is starting off with a positive reputation.
Any thoughts on the FRAM oil filter?
  #11 (permalink)
Old 10-29-2009, 10:17 AM
bismic's Avatar
The Frams now seem to have the felt on the bottom and have all the patent numbers. They should be the same. I have read more than one post where they were found to be different though. Some people speculate that people switched them in the store. The main thing is to be sure you are getting the correct ones:
1. felt on the bottom
2. U.S. Patent 6.554.139 describes the filter components (the good stuff, made by the Parker-Hannifin Corporation).
3. U.S. Patent 6.086.763 refers to the front disk assembly (not quite as important - made by Ing. Walter Hengst GmbH & Co.).
Make sure Oil filters are OEM style. Check:
1. One piece top (NO plastic cap adaptor)
2.Top is glued to the filter media
3. Patent numbers (above)
4. Felt gasket on bottom
5. Diameter - exactly 1.5"
6. Length - exactly 6.5" (excluding the 4 snap tabs on top)
7. Filters are stiff and resist any twisting motion
8. 52 or 53 pleats
9. Pleats are 11/16" wide and 6 3/8" tall
__________________
Mark
  #12 (permalink)
Old 10-29-2009, 11:10 AM
69cj 69cj is offline
69cj has a good reputation on FTE. 69cj has a good reputation on FTE.
8. 52 or 53 pleats
Mark, You really need to get a hobby!!
__________________
"05 F-250, 6.0, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, Magnefine p.s. filter, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
173rd Abn.
  #13 (permalink)
Old 10-29-2009, 07:38 PM
cheezit cheezit is online now
cheezit is gaining momentum as a positive member of FTE.
take the time and check base oil pressure. the bb bing shot out has a tendancy to stick the regulator at 70 psi. the regulator is located in the bottom of the front cover
  #14 (permalink)
Old 10-29-2009, 10:35 PM
RynL88's Avatar
will do.. thanks
__________________
  #15 (permalink)
Old 10-29-2009, 10:44 PM
RynL88's Avatar
will do.. thanks
Isn't there a fitting someone sells that I can use? I remember reading it in a thread somewhere recently but can't find it through the search now
just point me in the right direction if you could
__________________
Tags
2006 , 60 , branch , crank , cranking , f250 , ford , forum , hpop , long , powerstroke , problems , psd , sits , times , truck , tube
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
