TECH folder - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
TECH folder
Closed Thread
Old 10-20-2009, 09:55 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
TECH folder
This is the Ford V10 6.8L Tech folder.
Please read the "Taking submissions for the TECH folder" and post your suggestions for links to threads with pertinent information.
Old 10-20-2009, 09:56 AM
Krewat's Avatar
Wondering why your MIL doesn't come on? Or in other words, wondering why your truck doesn't have an O2 sensor after the catalytic converter or a bunch of other weird things, like why your state can't do an emissions inspection?
http://www.ford-trucks.com/forums/51...t-come-on.html
Changing exhaust studs, removal of broken ones, etc
http://www.ford-trucks.com/forums/85...t-it-info.html
My own thread about removing studs and installing eBay headers:
http://www.ford-trucks.com/forums/sh...d.php?t=593174
Thread on y-pipe, and lots of comments from people who actually did it:
http://www.ford-trucks.com/forums/65...h-results.html
And more y-pipe threads to read:
http://www.ford-trucks.com/forums/40...s-y-pipes.html
http://www.ford-trucks.com/forums/60...t-flutter.html
Clean your MAF
http://www.ford-trucks.com/forums/sh...=1#post8490555
For pictures of MAF removal and a procedure, look at the Volant CAI install thread at:
http://www.ford-trucks.com/article/i..._F250_V10.html
Volant CAI installation on a 2-valve 2001 V10:
http://www.ford-trucks.com/forums/77...-2001-v10.html
Superchargers:
http://www.ford-trucks.com/forums/51...g-whipple.html
A 3V in a 2V truck:
http://www.ford-trucks.com/forums/85...ue-solved.html
Synthetic oils:
http://www.ford-trucks.com/forums/87...hetic-oil.html
Replacing a V10 - lots of great info about E-series vs. F-series engines, 2-valve
http://www.ford-trucks.com/forums/94...2000-f350.html
A note about 2004 and 2005 2-valve PCV valves and gas mileage
http://www.ford-trucks.com/forums/98...cv-valves.html
Hedman header install, thanks to ak-angler
http://www.ford-trucks.com/forums/10...ll-w-pics.html
Some great COP info, from devongarver
http://mustangforums.com/forum/6314454-post1.html
Old 10-20-2009, 10:26 AM
Krewat's Avatar
FUEL mileage polls:
Old 09-22-2010, 10:29 AM
Krewat's Avatar
Spark plug thread and factory procedure changes.
After much hemming and hawing, I have decided to put this info in the tech folder. This is from a document that Ford provided to the NHTSA a few years back in 2005 in response to an investigation that was closed by the NHTSA because it was not deemed a "safety" issue. It was reviewed again in 2007 and again deemed to not be a safety issue because of the number of complains (total of 652 by 2007) versus the number of engines total (over 10,000,000).
My review of documents related to this (which I won't include here) show that after the model-year 2002 changes to a long-thread head, the 2003-2004 model-year shows a substantial reduction in plug blowouts. Of 652 complaints, NONE were shown to cause any damage to the hood, cause a fire, or a gas leak of any kind. Stalling was possible but again in very rare cases, and a restart was usually possible except in ONE case.
Running spark plug changes:
December 1996 - 4.6L 4V alignment feature added
February 1997 - 4.6L 2V head alignment feature added
September 2000 - WEP (Windsor Engine Plant) 2V head alignment feature modified (4.6/5.4/6.8)
November 2002 - WEP introduced long thread heads on 2V (all)
May 2003 - REP (Romeo Engine Plant) introduced long-thread heads on 4V 4.6 and 5.4
November 2003 - REP introduced long-thread heads on 2V and modified alignment feature
In 1999, and 2001, an interim fix was done for a cross-threading issue.
Original process:
Step 1 - Zero torque spark plug (air tool)
Step 2 - Torque to 16-20Nm final torque (DC Run down), monitor at 6-12Nm, and final torque must be reached within 0-360 degrees.
New process (addressed the possibility of applying installation torque for more than 25 degrees of rotation)
Step 2 - Torque to 16-20Nm final torque (DC Run down) start monitor at 6-12Nm, and final torque must be reached within 3-25 degrees.
Another action to address cross-threading was the addition of an alignment feature to lead the plug into the hole.
Old 02-14-2013, 10:17 AM
Krewat's Avatar
AFTERMARKET PART NUMBERS AND TECH INFO
Whipple supercharger belt part #'s, thanks to green250
whipple belt part # - Ford Truck Enthusiasts Forums
Old 03-21-2016, 08:53 AM
Krewat's Avatar
Blown plug fixes
An excellent Timesert how-to with pictures, by tmehrkam
http://www.ford-trucks.com/forums/99...th-photos.html
Nominated for the tech folder by Wolfboro - THANKS!!!
Closed Thread
Tech folder DavidB 1999 to 2016 Super Duty 2 12-04-2015 03:22 PM
Tech tips Krewat Ford In-Vehicle Tech 2 08-04-2015 12:51 PM
TECH folder dannyboy950 6.0L Power Stroke Diesel 0 03-18-2015 01:10 PM
PDF links on changing oil in Tech Folder is broken TruckingBill 6.0L Power Stroke Diesel 10 10-19-2014 06:00 PM
Excursion Forum Tech Folder Stewart_H Excursion - King of SUVs 0 02-02-2012 12:52 AM
Tags
2v, 46, broken, exhaust, ford, have, modified, o2, sensor, studs, tech, truck, type, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
