Idles Rough after warming up - Ford Truck Enthusiasts Forums
Old 10-20-2009, 06:23 AM
pbutland pbutland is offline
pbutland is starting off with a positive reputation.
97 Ford 4x4 F150 auto with 4.6 Lariat. Truck appears to run OK cold. After warming up the idle is rough and wants to stall. The truck has 69,000 miles. Sits in the garage alot. Original plugs and wires. I checked the IAC and it looks clean. I believe the IAC is OK due to the fact when the RPM at idle starts to die all of of suddent the rpm will pick up in an attempt to keep the truck running.BTW no CEL. My question is would an open EGR valve cause this problem ? No other problems other than IDLE after warming up. Just happened all of a sudden.
doesnt like the cold minitrk 1997-2006 Expedition & Navigator 2 10-19-2012 08:35 AM
Surging Idle and drive when Cold! dchough 1987 - 1996 F150 & Larger F-Series Trucks 27 08-14-2012 01:38 PM
Truck will only idle at 500 rpm? twp 1997 - 2003 F150 18 07-05-2012 06:24 AM
stumbling under load Black Ford XLT 1978 - 1996 Big Bronco 20 06-08-2011 05:44 AM
Truck stalling. IAC Problems? and401 Modular V10 (6.8l) 7 03-30-2010 06:57 PM
Tags
1994, 1997, 1999, 46, dtcs, expedition, explorer, f150, ford, idle, idling, rough, runs, warm, warming
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
