Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-20-2009, 12:10 AM
Jake331 Jake331 is offline
Jake331 is starting off with a positive reputation.
6637 intake
I keep hearing about so what is it?
  #2 (permalink)
Old 10-20-2009, 12:55 AM
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch is starting off with a positive reputation.
napa part # 6637 air filter. use a small piece of 4" pipe with a 45* bend to fit it up. or you can use a longer piece of pipe with a 45 at the end and use a 4" coupler to attach it to the intake. Clay at riffraff diesel carries all the parts to put it in and its pretty cheap. if you want to built the kit yourself get the filter from www.fleetfilter dot com. about 40 bucks after shipping i believe.
__________________
DEATH ROW DIESEL INMATE # 7-- TRAVIS
1995 F-250 PSD- Tony's tunes, CPR fuel system, 120v IDM, T.E 17* HPOP, DIY stage 2's, val-air full ceramic clutch, ISSPRO's, 3" dp-5" stacks, IC, ccv mod, 6637.... DYNO'D 352hp/731tq w/ stage 1's........... '94 F150 SC SB 4x4 5 speed(PROJECT!)
  #3 (permalink)
Old 10-20-2009, 06:10 AM
cool does anybody have any pics?
  #4 (permalink)
Old 10-20-2009, 07:27 AM
Hussler's Avatar
Hussler Hussler is offline
Hussler is gaining momentum as a positive member of FTE.
Quote:
Here you go ...
__________________
Jim
1997 F250 HD CC 4x4 7.3L - E4OD - 3.55's
EVBP Disconnected - Napa 6637 - FPR Shim
3" Down Pipe & CD - 203 Stat - 163 K Miles
  #5 (permalink)
Old 10-20-2009, 07:58 AM
rideracelivemx7 rideracelivemx7 is offline
1995 Ford F-250
rideracelivemx7 is starting off with a positive reputation.
great easy quick to do, whistles at higher rpms building boost and traps some major dirt! fantastic filters
__________________
red 7.3 powerstroke diesel-6637-10k-6 POS chip big name tunes-HPX line-3" Downpipe--> 6" Aussie stacks! 3:55s auto-122k miles-Rotella Synthetic, ebpv butterfly removed
  #6 (permalink)
Old 10-20-2009, 08:30 AM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is gaining momentum as a positive member of FTE. riverrat41 is gaining momentum as a positive member of FTE.
I agree with all above.You will love the sound and better filtration for your turbo.You might want one of these as well.Pete makes a great cover and can do some awsome graphics..FilterCovers
__________________
Barry.....FISH HUNTER!
Tony Wildman Chip , 4''Exhaust, 6637w/Pete's Cover, Crossover, AIH Delete, Foil Delete, WW, Ped Gutted, Tugger Kit, Isspro Gauges, CCV, Recon smoke cab lights, Camo seat covers, Replacement Bumpers, Hutch/Harpoon ,Cold A/C Mod, True Cool
  #7 (permalink)
Old 10-20-2009, 11:09 AM
Talyn's Avatar
Talyn Talyn is offline
1994 Ford F-250
Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE.
Riff raff has a kit for the 6637 mod.
filter and a powder coated 45.
make sure you tell him its an OBS.
its pretty cheap also.
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 - F250 - Direct Injection Turbo Diesel, 5 speed, 4x4, Standard Cab.
Rosewood Stage 1's, 6 pos PHP Tuner, 6637, Midwest Short Throw Shift Kit, Stancore GPR.
Midwest Shift Kit- http://www.midnightmods.com/2009/11/...ifter-kit.html
Quote:
Originally Posted by Action4478
the columns aren't made out of marshmallows...Just wiggle it ....
  #8 (permalink)
Old 10-21-2009, 06:24 AM
ok so the filter just lays there in the old air box spot. is there any noticable performance gains? should be a good as any after market intake other maybe pulling in more hot air.
  #9 (permalink)
Old 10-21-2009, 08:12 AM
riverrat41's Avatar
It is not going to jerk your neck back but you will tell a difference and you know there is clean air going to the turbo.It works well with other mods down the road.....Like Talyn says,Clay has a kit to do the CCV and filter all in one.I thought you might want to look at different cover schemes is why I sent the link to Covertek.
__________________
  #10 (permalink)
Old 10-21-2009, 08:31 AM
Butch(OH) Butch(OH) is offline
Butch(OH) is gaining momentum as a positive member of FTE.
I installed the filter and a 3" downpipe at the same time so I dont know how much credit to give to what mod but I can say that the combination got rid of a lot of turbo lag and raised my peak boost number by 3-4lbs. This is with no muff nor kitty and 4" exhaust.
__________________
2000 F-250SD 5.4 (210,000 and counting)
2005 Exploder
'97 F-Super Duty 5 speed flatty
6637 Filter -3" Down pipe -SM flywheel & clutch
Autometer Phantom IIs pillar mounted.
My Kitty is lost, anybody seen it?
  #11 (permalink)
Old 10-21-2009, 09:03 AM
at idle for extended periods of time is the only time that there would be a lot of hot air going in the intake. when your driving down the road so much air is pulled into the engine compartment that the underhood temps aren't bad and are of no concern.
__________________
  #12 (permalink)
Old 10-21-2009, 11:39 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
My Garage
Brown Falcon is starting off with a positive reputation.
It's just as good as just about any other aftermarket intake kit. The only way to make it better would involve making a sealed box around it with a cold air supply. But like Strokin'_tatsch said you won't have a problem with hot air except when at idle and not moving
__________________
Brownie, Ooh-Rah! USMC Member of the NRA!
'95 F350 CC 4x2 - SRW Swap, E40D, PHP 6 Pos. Chip, 6637 mod, 3" D.P., Lost Kitty, 140v IDM, HPX Mod, FPR Shim (65 psi), T.C. switch, 3.55 gears
'88 F350 CC 4x4 - lots of dents, faded paint, old 7.3 IDI in pieces
  #13 (permalink)
Old 10-21-2009, 12:10 PM
maverick1701's Avatar
maverick1701 maverick1701 is offline
maverick1701 is gaining momentum as a positive member of FTE.
it is the holy grail of air filters...
__________________
Chris
M35A2 Deuce and-a-half
1996 F350 Crew-Cab 4x4 7.3 Powerstroke SRW
217K miles; 6in suspension lift; 33in BFG M/Ts; T3 "Get outta my way mod" w/warn 12K winch; WARN hubs; CB; Gauges; Herculined inside cab; 2008 Center console
  #14 (permalink)
Old 10-21-2009, 01:05 PM
Talyn's Avatar
1994 Ford F-250
A guy dynoed his truck here locally and they bolted on a K&N Cold air kit to his diesel.
I'm pretty sure it was a dodge, coulda been a chevy.
anyways.
he lost 8 hp with the K&N cold air kit.
__________________
  #15 (permalink)
Talyn's Avatar
1994 Ford F-250
anyways.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
