Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-22-2009, 12:21 AM
jbeecham jbeecham is offline
jbeecham is starting off with a positive reputation.
Great Deal for the Money
This is the first thing I did when I got my truck a few months ago. I definately would recommend it as I feel like the truck is breathing better. The only trouble I had was finding the 45 locally. Someone recommended that I try a big truck parts house, and they had it in stock. Just a suggestion if you want to chase down your own parts.
  #17 (permalink)
Old 10-23-2009, 06:35 AM
Jake331 Jake331 is offline
Jake331 is starting off with a positive reputation.
ok guys thanks for all the info.
  #18 (permalink)
Old 11-04-2009, 06:25 AM
Towmanjbo's Avatar
Towmanjbo Towmanjbo is offline
Towmanjbo is gaining momentum as a positive member of FTE.
Hello all, I want to make one of these for my F150 as well do we know if there is a smaller filter that would be better for the old 300-6?
__________________
Justin
1996 F250 XLT Xcab 4x4 7.3 E4OD
1993 Bronco XLT 4" lift w/ 33"s 5.8 E4OD (sold)
1992 F150 Custom/XLT 4x4 4.9 E4OD
1983 F150 Custom/XLT 4x2 4.9 C6
  #19 (permalink)
Old 11-04-2009, 06:57 PM
stewart460's Avatar
stewart460 stewart460 is offline
stewart460 is starting off with a positive reputation.
so you buy this 8837 and just buy a 45 bend and it fits right in ?
  #20 (permalink)
Old 11-04-2009, 06:58 PM
stewart460's Avatar
i mean 6637
  #21 (permalink)
Old 11-04-2009, 10:17 PM
yoslick's Avatar
yoslick yoslick is offline
yoslick is starting off with a positive reputation.
Basically yes, I used PVC sewer connections for the bend and the extension I got from Menards... Little gloss black spray paint and it looks and works great!!
__________________
96 F-250 Ext-cab 4x4 7.3 Long Bed
DIY Air filter (NAPA 6637)
3" DP,HPX,Gutless Kitty
14.6k Mod
DCC(SW/MTS) USN-Ret 75-95
  #22 (permalink)
Old 11-04-2009, 10:32 PM
CampSpringsJohn CampSpringsJohn is offline
CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold
Quote:
Originally Posted by stewart460 View Post
so you buy this 6637 and just buy a 45 bend and it fits right in ?
Assuming you're talking about a 7.3 powerstroke engine, then basically, yes. You will need to get rid of the factory air box to make room, and the filter just sits on the wheel well. As stated above, Clay at Riffraff Diesel a site sponsor, sells a complete kit for both the 94 to 97 models, and the 99 to 03 models. I chased down parts when I did mine, but Clay wasn't up and running at the time. You will save time by ordering his kit. The only drawback to this kit is that when you're towing, there is a pretty good drone coming from the filter that might annoy some folks. It don't bother me, or most folks, but it does some.Some folks have fabricated boxes to shield the filter from the back of the engine compartment that have had success at reducing the drone.
__________________
1997 Super Duty, PSD,6637, high idle, 50hp, & 80hp. 150cc injectors.
2002 F250 Crew Cab, 8' bed, 4X4, PSD, 6637, 4" magnaflow exhaust, high idle, 50, 75 tow, 100, 120, & 140, HPX Crossover
Kentucky Chapter Member
  #23 (permalink)
Old 11-05-2009, 10:47 AM
Slimsadie Slimsadie is offline
Slimsadie is starting off with a positive reputation.
I just ordered one last night from riffraff. Can't wait
  #24 (permalink)
Old 11-05-2009, 04:48 PM
stewart460's Avatar
great this will increase the throttle response? and on the last page they were compairing it to cold air and i just want to be sure which is actually better
  #25 (permalink)
Old 11-05-2009, 04:52 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
My Garage
Brown Falcon is starting off with a positive reputation.
If the truck is moving there will be cold air coming to the filter from outside. The only time it would be getting a lot of hot air is if you are sitting still idling when you don't need the extra power.
I've seen guys make custom "boxes" around the 6637 filter but don't know if it really helps it at all.
As far as throttle response you might notice a slightly faster spool up of the turbo but probably not a really big power difference.
__________________
Brownie, Ooh-Rah! USMC Member of the NRA!
'95 F350 CC 4x2 - SRW Swap, E40D, PHP 6 Pos. Chip, 6637 mod, 3" D.P., Lost Kitty, 140v IDM, HPX Mod, FPR Shim (65 psi), T.C. switch, 3.55 gears
'88 F350 CC 4x4 - lots of dents, faded paint, old 7.3 IDI in pieces
  #26 (permalink)
Old 11-05-2009, 04:58 PM
stewart460's Avatar
ok so if im looking at this or a cold air intake what would be your guys choice
  #27 (permalink)
Old 11-05-2009, 05:00 PM
1995 Ford F-350
My Garage
I would vote for the 6637. Better filter, better price, no fancy parts...
__________________
  #28 (permalink)
Old 11-05-2009, 05:07 PM
stewart460's Avatar
yeah i was looking at the 6637 and it was cheap like 69 bucks for the kit . does this intake improve fuel milage
  #29 (permalink)
Old 11-05-2009, 05:15 PM
1995 Ford F-350
My Garage
Don't know on the mileage part... I changed up so many things on my truck around that same time that I couldn't tell ya
__________________
  #30 (permalink)
Old 11-05-2009, 07:19 PM
Quote:
Originally Posted by Brown Falcon View Post
I've seen guys make custom "boxes" around the 6637 filter but don't know if it really helps it at all. .
I believe the custom boxes were done in part to help reduce the drone noise.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
