Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-19-2009, 10:36 PM
kwemj 67 kwemj 67 is offline
kwemj 67 is starting off with a positive reputation.
Lightbulb Which is better, D0VE block or C8VE ?.
Would like to get your input on what is a better block ?. The 70 ( D0VE) or a 68 (C8VE). I Have the 70 style in my 78 F250 S/C 4X4 right now and also have a 68. Is there any difference between the two, other than the year. I know the 68 heads have larger studs than the 69-70, just thought I would get some input on this subject. Also had a question on how to post some pictures of my truck. Thank's. Kelley.
  #2 (permalink)
Old 10-19-2009, 10:58 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
1974 Ford F-100
My Garage
Bullitt390 is gaining momentum as a positive member of FTE. Bullitt390 is gaining momentum as a positive member of FTE.
The newest block you can get, A D2 is preferable over a D0. Both are more desirable than the C8 and C9.
Josh
__________________
1974 F100 Custom Styleside Dual Quad 428 Cobra Jet
  #3 (permalink)
Old 10-20-2009, 10:35 PM
Smile Re: D0VE or C8VE
Thank's for the input on the D2 block being better. Did the D0 and D2 blocks have a higher nickle content or thicker walls to make them a better choice?.
  #4 (permalink)
Old 10-20-2009, 10:57 PM
Bullitt390's Avatar
1974 Ford F-100
My Garage
I think it had more to do with better casting and less core shift.
It's more important to pay attention to what block you have and what rotating assembly you install. The early blocks have a lower deck height than the 72 blocks and later 460 79 blocks.
Josh
__________________
  #5 (permalink)
Old 10-21-2009, 06:18 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Originally Posted by Bullitt390 View Post
The newest block you can get, A D2 is preferable over a D0. Both are more desirable than the C8 and C9.Josh
There is no such thing as a D2 (429/460) block.
Block casting numbers that followed DOVE:
D1VE-6059-AB, -AB1, -AB2.
Fits: 1971/73 429 Passenger Cars / 1973/78 460 Passenger Cars/F100/350's / 1975/78 Econoline's / Some 1979 460's as installed in F100/350's and Econolines.
These D1VE blocks do not use a weighted spacer. 460 engines were not available in 1979 Passenger Cars.
ALL 1968/78 Lincoln's & Mark's have 460's / 1972 T-Bird's were available with 460's as an option over the 429.
1973 T-Bird's, Galaxie/LTD's and Merc Marquis were availabe with 460's, again as an option over the 429.
No 429's after 1973.
Midyear 1979: Ford changed the 460 block. The casting number is D9TE-6059-AB.
This block uses a weighted spacer. The flywheel and harmonic balancer are not the same as the D1VE blocks.
Since this was a "running change" in 1979, there is no before/after a certain production date or serial number.
__________________
Bill / Retired Ford Parts Manager / Ford Historian / SoCal Chapter Member
  #6 (permalink)
Old 10-21-2009, 06:45 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation monsterbaby has a superb reputation
Josh
Actually the newest 460 block was the D9TE-AB block that was used until the 460 was taken out of produciton.
Which is better? really a mute question. The D9TE blocks have a little advantage for strokers due to the longer cylinder walls better supporting the piston at BDC.
The D0VE blocks usually had a little heavier main webbing but it is really irrelevent since there are plenty of D9 blocks surviving at 700+hp
Basically none of htem have any real serious advantage over any other. There is NO truth to the wives tail about higher nickle content or ability to bore one year more then another.
__________________
Rob
2000 F250 7.3 psd 1/8th mile 9.35 @ 70.5mph
1967 Galaxie 390 1/8th mile 8.13 @ 84mph
  #7 (permalink)
Old 10-21-2009, 08:13 AM
Thank's for your input, and numbers. I had heard that comment before about the 70's block having higher nickle content, just wanted to clear it up. Thank's again. Kel.
  #8 (permalink)
Old 10-21-2009, 06:26 PM
Bullitt390's Avatar
1974 Ford F-100
My Garage
Quote:
You're taking my post out of context...
He asked about a C8 and D2... I said the NEWEST he could get which also includes the D9
Josh
__________________
  #9 (permalink)
Old 10-22-2009, 01:03 AM
Ford Parts Guru
He asked about a C8 and D2... I said the NEWEST he could get which also includes the D9 Josh
As I said in post #5, there is NO SUCH THING as a D2 429/460 block.
Block casting number prefixes: C8VE / C9VE / DOVE / D1VE / D9TE
Where is the so-called D2 casting prefix?
Usually casting numbers are not listed in parts catalogs, but they are for 1971/79 460 engines, because this was the ONLY way to determine what flywheel & harmonic balancers were used in 1979.
TWO different 460's were used in 1979, one has the D1VE casting number, the other has the D9TE casting number.
__________________
  #10 (permalink)
Old 10-22-2009, 06:31 AM
Josh
I would like ot also point out on top of what Bill wrote, IF there actually had ever been a D2 casting it would be OLDER then D9 block.
But since there was NOT a D2 block casting he would not be able to get it adn thus it would NOT be the newest block at all.
__________________
Rob
  #11 (permalink)
Old 10-31-2009, 01:10 PM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is starting off with a positive reputation.
I'm running a D1VE block. I had it square decked down to the D0VE deck hight. I can't remember the numbers off the top of my head and I don't feel like looking them up but I think it was a difference of .022. That gets my pistons to come up to TDC. I'm running C9VE head with that.
__________________
1977 Ford F-150 4X4 460 4-speed (dark jade metallic) Produced June 22, 1977
1966 Ford Fairlane 289 2 door hard top (black)
  #12 (permalink)
Old 11-01-2009, 11:28 AM
Smile Which is better?.
When I originally posted the question of which block was better or was there any difference, that was between a 68 block and the 70 block that is in the truck now?. Not a 79 or 72. Was just wondering if there was any difference between the two?.
  #13 (permalink)
Old 11-01-2009, 01:30 PM
And the basic answer was no there is not any significant difference that will affect what you are trying to do between those blocks. Use the one that is in the best shape (read that as will clean up with less bore, or has a straighter deck, is just cleaner etc)
__________________
Rob
  #14 (permalink)
Old 11-01-2009, 02:42 PM
Smile
Thank you again for your words of wisdom, master. From your pedawah learner!.
Tags
429 , 460 , 6059 , block , c8ve , codes , d0ve , d9te , difference , dove , ford , heads , numbers , serial , vin , vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
