Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-20-2009, 01:03 AM
Jermafenser Jermafenser is offline
Jermafenser is gaining momentum as a positive member of FTE. Jermafenser is gaining momentum as a positive member of FTE.
Not really. If it looks old/worn, just replace it. It's $5.
__________________
Chad
1997 F350 XL 4WD, 351W & E40D
1978 F150 Ranger XLT 2WD, 351M & C6
  #17 (permalink)
Old 10-20-2009, 01:04 AM
Another thing - if you want to see just how much fluid will push out of a wheel cylinder, install a clear hose over the bleeder screw. Have a buddy push down the pedal all the way down. If you see a geyser as fast as a bullet, it's good.
__________________
Chad
  #18 (permalink)
Old 10-20-2009, 01:07 AM
CrazyAirman's Avatar
CrazyAirman CrazyAirman is offline
CrazyAirman is gaining momentum as a positive member of FTE.
Don't crush the hoses with the clamps, squeeze them just enough to pinch them off. It won't hurt them.
__________________
I painted the dang thing camoflage, now I cant find it!!
74 F100 4X4 Grump-a-saurass
WAY more guitars than talent
  #19 (permalink)
Old 10-20-2009, 02:57 PM
alie-r's Avatar
alie-r alie-r is offline
alie-r is starting off with a positive reputation.
pull the little pin on the proportioning valve a little out when bleeding.
if you don't do that ,you never have pressure at the rear brakes.
you can read it in the 1978 truck shopmanual volume 1 chassis.
on page 12-24-3
andre
  #20 (permalink)
Old 10-31-2009, 10:37 PM
todd jo todd jo is offline
todd jo is starting off with a positive reputation.
I was able to replace the prop valve and that solved the problem, but led to another. The master was also bleeding by inside. Replaced that too. Now I got brakes again!!
Thanks guys
  #21 (permalink)
Old 10-31-2009, 11:49 PM
Riderman Riderman is offline
Riderman is starting off with a positive reputation.
Quote:
Thanks guys
Did you try to pull the little pin on the proportioning valve as was suggested before you replaced it? Prop valve's RARELY go bad. Master cylinder problems..common after several years of use.
  #22 (permalink)
Old 11-01-2009, 06:41 PM
The prop valve was a pain all the way through. I tried pushing it pulling it. It would never reset after bleeding the brakes and I had to tear it down on the bench to reset it so the light would go out. After all that I still had no rear brakes. I took a shot in the dark and just pulled one out of an abandoned project that I knew was good and stuck it in there. It was free$$ and I had rear brakes after I installed it. Then the pedal was sqishing out from under my feet. So I put on a new master and now I am happy again.
This is the second time I personally have had prop valve problems. Both times it was with rigs that had been sitting for years. On the other one I just used a wilwood adj. prop valve. This time I used a spare I had.
Todd
  #23 (permalink)
Old 11-01-2009, 09:00 PM
gstanfield's Avatar
gstanfield gstanfield is online now
gstanfield is starting off with a positive reputation.
Who needs brakes, all they do is slow ya down anyway
George
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
