I am a bit confused on the first post. You say you can't get it to turn over but then say there is no fuel flow from the pump. If the engine is not spinning over there will not be any fuel. If you mean it's turning over but will not fire, that is a different problem.
Generally the temperature needs to get below 20 degrees or so for a while before I have any kind of slower starting.
__________________
86 F-250 4x4
Cummins BT 5.9
GearVendor O/D
