Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-19-2009, 08:02 PM
RobDib RobDib is offline
RobDib is starting off with a positive reputation.
Shifting problems after battery/car jump.
Hello everyone, my name is Rob, a Google search indicates that you guys really know your s**t, especially of the FORD variety! Hopefully you can lend some insight into the following problem.
I recently acquired a 1999 Ford Expedition XLT - 5.4 Triton - AWD - w/110K miles.
I've had it for about a year, no problems - except for the factory alarm going off while driving, (lights flashing, horn blowing, etc.) but that is/was the only problem.
Today, the battery was dead, so i jumped the truck with another car, it didn't start right away (even with the other car revving), left it alone for a few minutes, and then it started.
Now, the problem , truck now doesn't shift, stays in one gear, while driving at around 10MPH, the speedometer indicates that the truck is doing about 80MPH (the Tach stays around the 1.5-2.5 range.) When i make left/right turns the truck feels like it's going to stall, and hesitates throughout the turn, there is a (very low volume) whining-type sound coming from under the hood, which goes up in pitch, the faster you travel. It almost feels like it's stuck in 4X4-Low (while the switch is on AWD), however, when i tried to toggle the switch from AWD to 4H and the 4L, it appears that it does nothing, the 4X4 is not operating. No 4X4 lights go on on the dashboard (when i operate the switch) either.
There are no warning lights indicating any problems on the dashboard, everything else works.
My auto mechanical knowledge is somewhat limited (however, i am an easy learner, and capable), it seems that something happened to the computer, are there any tricks, or perhaps anything that i should look into, before taking it to a mechanic?
Thank you,
Rob
  #2 (permalink)
Old 10-19-2009, 08:06 PM
madsonp madsonp is offline
madsonp is starting off with a positive reputation.
Try disconnecting the battery again for about 10 minutes, then reconnect it. Oh, and welcome to FTE, and yes we like to think we know our s**t.
__________________
99 & 97 Expedition EB 4x4 5.4L
77 E-250 4x4 Van 460ci & 76 E-350 Motorhome 460ci
42 Ford 9N Tractor (old pig)
  #3 (permalink)
Old 10-19-2009, 08:17 PM
That was the first thing that i did when i came home Madsonp, i guess i'll find out what happens tomorrow.
Thank you for the welcome, and yes, the high membership numbers are indicative of a strong knowledge-base (i.e., you guys know your s**t!) Kudos to all...
And thank you for the quick reply!
  #4 (permalink)
Old 10-19-2009, 09:28 PM
alloro alloro is offline
alloro is gaining momentum as a positive member of FTE. alloro is gaining momentum as a positive member of FTE.
Quote:
Why?
Old battery?
Wiring issue?
Bad alternator?
The reason for the dead battery could be the reason for the other issues.
__________________
If you like the advice you get, be sure and click the left red "Add to Reputation" button
to the right of the word "permalink" at the top right of the poster's message window.
  #5 (permalink)
Old 10-19-2009, 10:03 PM
Hello alloro,
The battery (DieHard) was purchased new in 04/08 by the previous owner, i bought the truck in 08/08, and since then i have put on perhaps 300-350 miles, mostly short trips (10-15miles round trip.)
I checked the water level back in December and it was low, i remedied that, but the battery never got a chance to fully charge; as i have yet to put it on a charger, or, take a long trip on the truck. There does seem to be a problem with the horn, sometimes it works, sometimes it doesn't, the doesn't tends to happen when it rains, it may be shorting, but unless i fully charge the battery i have no way of knowing, and yeah, i will be replacing the horn soon.
  #6 (permalink)
Old 10-20-2009, 07:01 PM
That would certainly explain why the battery died.
__________________
  #7 (permalink)
Old 10-27-2009, 06:05 PM
Well, a week later and i finally got a chance to hook up the terminals, started right up, which tells me that the battery is good. I then drove it, and everything is working as it should, i guess that the computer s/w-based management system somehow became corrupt when the truck was jumped last week. The system simply rebooted, and everything is perfectly fine, the 4X4 works, the tach/speedo is back to normal, and she shifts perfectly. I have also ordered a battery charger (Battery Tender Plus), so the battery issue should also go away...thanks for the feedback guys!
  #8 (permalink)
Old 10-27-2009, 08:45 PM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE. tseekins has a very good reputation on FTE.
Rob,
Glad to hear that you got her squared away. Stay with us and keep posting. Consider becoming a member, it's cheap and you get rid of those pesky ads.
Tim
__________________
SCPO United States Coast Guard Retired
'04 Expedition XLT 4x2
'99 Taurus Wagon SE 24V
'88 F-150 4x4 XLT Lariat 5.8L 5Spd
Rights of Passage: CPO Initiation, Submarine Qualified (SS), Golden Shellback, Blue Nose, Order of the Ditch
Tags
2004 , 24v , battery , car , died , f150 , ford , gears , jumps , problem , problems , shift , shifting , speedometer , taurus , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
