Choosing the right AOD for a 4X4???? - Ford Truck Enthusiasts Forums
Old 10-19-2009, 06:30 PM
mattj mattj is offline
mattj is starting off with a positive reputation.
Hi guys, I have a 83 f150 2wd in decent shape i've been driving for a while and was planning on restoring. Now im thinking i want a Crew cab 4X4 instead. There abit harder to find at least around here. I found a '91 that has a spotless cab and frame thats crew and 4X4 and cheap. It's fuel injected and I want to build a 351 Cleavor for it(carb'd). I want auto with overdrive, but im pretty sure the transfer cases are different. SO, did the earlie F/I veicles have the AOD without electronic controls? Or will the newer transfer case bolt up to a older AOD? Any ideas guys, or do I keep looking for a older truck with what i want. Thanks in advance!
Old 10-19-2009, 08:40 PM
Something i assumed was that when they went to fuel injection they also went to electronic controlled transmissions. Is this true?
Old 10-19-2009, 09:28 PM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
I know my friend's 86 Bronco with a EFI 302 has the 4x4 AOD tranny. Its now on the 3rd tranny as they don't like "abUSE" of playing in the mud.
Most Ford xfercases should bolt onto a AOD as long as it's setup for 4x4 applications. Now if you going to use a 351Cleveland, I don't think the bellhousing will fit the engine. If its a 351 Winsor, it will fit, but I doubt the AOD in stock form will hold up. Got to beef it up or put a C6 in as my friend is doing now!
Old 10-19-2009, 09:37 PM
Im building a Windosor Block Cleavland head setup. So its going to bolt up to the block. I heard the 90/ 91 AOD's were built stonger than any previous year, I was hoping to go with one of them, but im not sure if they are computer controlled or if they are still completely mechanical at that age. Im not planning on bieng in the mud alot, more of a driver that might go for some fun occasionally. Thats good to hear about the t-cases thanks.
Old 10-19-2009, 10:24 PM
Chitownhillbilly's Avatar
Chitownhillbilly Chitownhillbilly is offline
Chitownhillbilly is starting off with a positive reputation.
Quote:
The AOD is not a computer controlled transmission. For what it's worth its barely worth putting in a truck. It's basically a car tranny that had a hard time handling the power and weight of a Thunderbird, let alone a full size pickup. There are a couple builders that still know what they are doing with an AOD but it's going to cost a butt load.
In the long run you would be better off with an E4OD and a stand alone computer for probably the same money you'd have in an AOD able to handle the power of a built motor and the weight of a Crew Cab.
Old 10-19-2009, 10:50 PM
82F100SWB's Avatar
82F100SWB 82F100SWB is offline
82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.82F100SWB has a very good reputation on FTE.
A crew cab will have either a C6 or E4OD in it if it's auto, no AOD in anything heavier than a half ton.
Old 10-22-2009, 09:06 PM
The c6 is just a 3 speed right? Somone told me that since all tcases are made by mostly the same 2 companies, they all line into the transmission the same throught the big 3. Eg a dodge tcase in a f350. Is this true? And somone is trying to sell me a 2wd tranny saying a tcase can be hooked up to it... tailstock has the o/d unit in it doesnt it? Thanks Matt
Old 10-23-2009, 04:03 PM
Yep the C6 is only a 3spd. Most xfer cases are buit by Borg-warner or New process in our years of trucks. But one built for a dodge or chevy may not even fit a Ford tranny, as some are for right side output and the Ford's are left side output. Also the the transmission mounting will be diffrent from the big 3. Best to stick with a Ford xfercase, those for most part are bolt on.
Do not get a 2x4 tranny, most times you will not be able to hook up the xfercase to it. The reason is the output shaft of the transmission will be longer and probly a diffrent spline count. Only way to use a 2x4 tranny is by a "divorce" set up xfercase, that was not a option in the 80 to 86 trucks, but the older Fords like 79 and older did have that set up.
Most transmissions I took apart and fixed had the OD unit in front of the tranny(A4ld tranny from by Bronco 2), not sure about the AOD as I have not detailed info on it. The tail end usually has the governor,parking mech and speedo gears.
Old 10-23-2009, 05:35 PM
Oh ok thanks for the info! Iknow dodge tcases are all new process... So you guys are thinking E40D... has any one tried a stand alone computer... impressed with it?
Old 10-23-2009, 06:12 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
you DO NOT want an AOD in anything other than a 1/2 ton 2WD with a crap 302, its all the abuse that trans can stand up to. I went through 5 rebuilds in my old 90, and that truck was stock suspension and only all terrain tires. The AOD is JUNK, and I would not put one in my lawn mower
Old 10-24-2009, 05:46 PM
cadunkle's Avatar
cadunkle cadunkle is online now
cadunkle is gaining momentum as a positive member of FTE.
Avoid the AOD. They are not truck transmission and absolutely not suitable for any 4x4 application. Some folks will build them to take the abuse but that gets spendy. Depends on what you want.
Firstly, a lesson I learned a long time ago... Give up on finding an old truck that is everything you want. Buy one that is all around decent, minimal cab rust, etc. and is close to what you want. Then do it up how you want it.
I couldn't find a lifted '80-'86 Supercab F-350 with 460 and 5 speed, so I bought an '68 Supercab F-250 with 351w/C6. Swapped a Dana 60 into it, 4" lift, 460 swap, ZF5 swap... Bam, now I have the truck I want. Easy as pie.
So, if you must have a slushbox, go with either an A4OD o a C6 (A4OD is like a C6 with overdrive). Or be done with the slushbox junk and get a ZF5, or NV4500 if you really wanna abuse it.
Old 10-24-2009, 06:31 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Well I'm going to present a counterpoint to all those that say the AOD is junk. The one in my '90 ext-cab 4x4 F150 sucessfully survived 8 years behind a cammed up 5.8 with me throwing all the abuse it had at it. The trans was a fresh rebuild with all the factory updates and it has a shift kit, and it's still going and working perfectly. The AOD has know weaknesses which can all be addresses to support just about any power level, so like anything else you have to pay to play. Early versions of this trans are notoriously weak and cannot be upgraded to later spec, the latest versions will take parts from the 4R70W which is still in use today, so an early '90's model is the best platform to start with.
If you think the AOD is expensive to rebuild then you won't like the E4OD.. it is THE most expensive Ford tranny to service. And since it is computer controlled the only way to use it is with the stock ford EFI computer or with a $1000 aftermarket controller.
For the intended use a properly prepared AOD will do the trick, if this was going to be an abused mud truck or a tow rig then a C6 or ZF manual would be a better choice.
Has anyone ACTUALLY performed the AOD swap of Danny Cabral's?? bareaneye 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-30-2012 11:10 AM
4wd automatic transmission AOD and C6 are they same length Milwaukee1979F150 1987 - 1996 F150 & Larger F-Series Trucks 2 11-23-2009 05:58 PM
2WD AOD to 4WD AOD hokie93 Clutch, Transmission, Differential, Axle & Transfer Case 0 11-04-2009 03:59 PM
Strength and durability of the AOD Pkupman82 Clutch, Transmission, Differential, Axle & Transfer Case 3 01-21-2006 10:03 AM
C6 to AOD conversion info needed 02FX4Dude Clutch, Transmission, Differential, Axle & Transfer Case 11 11-02-2004 05:47 PM
Tags
4x4, a4od, aod, car, conversion, e4od, fit, ford, kit, shift, tailstock, trans, transmission, truck, zf5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
