Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-19-2009, 06:42 PM
crmarshall crmarshall is offline
crmarshall is starting off with a positive reputation.
No Power
I have an 05 F250. Truck has 54,000 has never had the power it should. Pulling 5500lbs downshifts on any grade above 1%. Pulling a 4% this weekend at 55F ambient it slowed to 50mph with no wind. That hill is a mile at best. Took it to the 3rd dealer today, they plugged it in and took it for a test drive, couldn't find anything wrong. Any ideas? Fuel filters are new and air filter is clean. Larger exhaust and intake are the only aftermarket mod. Anyone know of a dealer in Utah willing to work on a problem not pointed out with a CEL?
__________________
[/SIGPIC]
2005 F250 Crewcab XLT Lariat FX4 6.0 PSD
4" tough country lift.
4" exhaust with Banks muffler.
35" Toyo O/C on 18" wheels.
AFE cold air intake.
Firestone Airbags with compressor.
Turbo Liner
Auto Meter NV EGT gauge.
  #2 (permalink)
Old 10-19-2009, 07:16 PM
JaySVX's Avatar
JaySVX JaySVX is offline
2004 Ford Excursion
JaySVX is gaining momentum as a positive member of FTE. JaySVX is gaining momentum as a positive member of FTE.
Just a shot in the dark, but did you try taking off your dress and putting on a pair of Levi's and plaid button down first?
Are you pulling on tow/haul mode? the F250 6.0's have hte 4speed right? When you say it doesn't have the power it should, do you have a basis for comparrison? Are you pulling in 3rd or 4th?
Also, where do you get your diesel fuel? Do you consistantly buy from the same place, do you mix it up? I've heard of certain station having poor diesel fuel, and have experienced it myself once, it was noticably less powerful. It was grueling, and it lasted until about 20 miles into a new tank once it was drained to 1/4 tank. I talked to my mechanic about it and he said it was probably fuel, and asked where I had gotten it last. I remembered I was out of the local area when I had fueled up and had to get it from a local brand to where I was, not the normal Sunoco that I fuel up on.
__________________
2004 Ford Excursion 6litre PSD
Quote:
Originally Posted by ncheavymetal View Post
But I have an excursion and don't concern myself with matters such as "how much does it weigh?"
Quote:
Originally Posted by Maxium4x4 View Post
I would drive 1,500 miles out of my way rather than to walk through the front doors of any WalMart, OH look! TruckNutz isle 5
  #3 (permalink)
Old 10-19-2009, 08:29 PM
Bulldog66 Bulldog66 is offline
Bulldog66 is starting off with a positive reputation.
4spd? Behind a 6.0?
The OP didn't state, exactly, what the truck is. Are we talking Powerstroke? (have to ask, even though this is the 6.0 section). What gears? What load? Tire size? Lift?
What do you mean by "never had the power it should"? Is there more than normal turbo lag? (assuming powerstroke).
Lot's of variables here.
Just asking...
  #4 (permalink)
Old 10-19-2009, 08:48 PM
JaySVX's Avatar
2004 Ford Excursion
Quote:
Originally Posted by Bulldog66 View Post
4spd? Behind a 6.0?
Just asking...
Bah, you're right. I was just in the Excursion forums where there's the v10 and 7.3 with 4speeds, and only the 6.0 with the 5speed. Blah. Still, are you pulling in top gear, or in 4th? A 4% grade with 5500lbs in 5th, I would expect it to be a dog. I wouldn't expect it to go down to 55mph quite, especially if you were maintaining higher prior. In fact, I would expect it to downshift to maintain speed.
__________________
  #5 (permalink)
Old 10-19-2009, 08:52 PM
mxer0022's Avatar
mxer0022 mxer0022 is online now
mxer0022 is gaining momentum as a positive member of FTE. mxer0022 is gaining momentum as a positive member of FTE.
where in utah do you live?
__________________
"Ford, Because Driving A Chevy Will Give You Herpes"
2006 F-250 6.0L powerstroke cc 4X4 amarillo special edition
MBRP 4" T-409 turbo back w/cat delete
autometer Phantom II Pyro, 0-60 boost and tranny temp gauges
SCT Xcal3 w/custom tunes
  #6 (permalink)
Old 10-20-2009, 03:52 PM
I have 3.73 gears running 35 in bfg muds. It is a PSD. I had an 04 prior that would pull the same trailer 75 up a steeper grade and never blink. I am using the tow/haul mode. Not sure what gear it is in. I was doing around 65-70 approaching the hill. I live in Utah County. It has done this over the last several months. Fueled at multiple stations with no change. Hope that answers all the questions.
One more on my part. None of the 3 dealers I have been to want to do any Real trouble shooting. The best I have gotten is the current dealer who offered to have a tech ride with me with a trailer hooked up. They all just plug it in and say all the sensors read OK. What do I have to do to get them to actually inspect things like injectors or EGR valve?
__________________
[/SIGPIC]
Turbo Liner
  #7 (permalink)
Old 11-06-2009, 06:39 PM
Take the truck, loaded with trailer and all and go get a TECH, not a service writer. Plant him in the truck with you and go show him what the truck is doing.
Sometimes it takes a little persuasion, but persistance will pay off here.
Let us know what happens!
  #8 (permalink)
Old 11-06-2009, 08:26 PM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of
An '05 has a boost gauge. How many PSI is it blowing at full load?
__________________
Folks call me Bill.
Please pass the GREEN nozzle.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto.Fleetwood Pioneer,23'x5,200#
  #9 (permalink)
Old 11-06-2009, 08:31 PM
bismic's Avatar
bismic bismic is offline
bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold bismic is a splendid one to behold
Here is a quick list I put together on the things that can affect power (in relative order of "cheap and easy to resolve" to "most expensive"):
- Boost leak (CAC tube): check for leaks.
- Clogged air filter: check filter minder or just replace the filter.
- Plugged fuel filters: replace filters w/ OEM filters.
- Aerated oil (wrong/worn-out oil OR too much oil): change oil properly.
- Wire chaffing: check problem areas.
http://www.thedieselgarage.com/forums/attachment.php?attachmentid=17301&d=1208412696
http://www.thedieselgarage.com/forums/attachment.php?attachmentid=17301&d=1208412697
http://www.thedieselgarage.com/forums/attachment.php?attachmentid=17301&d=1208412698
- Bad fuel.
- Clogged fuel lines: Check system (run pressure check if you can).
- Air in fuel: check filter caps and lines for leaks.
- Bad EGR valve or clogged EGR valve: clean EGR valve.
- Clogged EBP, MAP sensor tubes: clean tube / hose.
- Stuck turbo vanes: clean turbo or replace center section.
- Injector stiction: get latest flash or maybe use HotShots.
- Having your truck flashed when you did not return your tuner to stock.
- Improperly completed flash.
- Bad MAF sensor: replace sensor.
- Bad ICP sensor or harness (usually will have rough or no-start w/ this).
- Bad IPR valve (or restricted IPR valve due to solids on the inlet screen).
- Bad VGT actuator. Replace actuator.
- Bad fuel pump (HFCM).
(you MUST have a minimum fuel pressure of 45 psig at all times or you risk expensive injector damage).
- Leaking EGR cooler. Replace or eliminate the EGR cooler.
- Bad injectors. Identify and replace leaking injector(s).
- Bad FICM, usually there are quite a few codes w/ a bad Fuel Injection Control Module.
- Bad HPOP. Usually a "no-start" condition will be experienced with a bad high pressure oil pump. It is a fairly big/expensive job to replace this pump.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20; DieselSite Coolant Filter; High Idle Mod; HFCM Plug; Zoodad/Air Fury grill; Accufab Elbow; RACCCV6000 filter; JimmiJammers; Ravelco; SynchroMax in Transfer Case; Fumoto Valve; Harpooned fuel tank; Line-X; CPOhighway Products tool box; tracrac; Fox Weatherboots; Wet Okole Seat Covers; Stanadyne Performance & B2 for lubricity; PIE adapter (thanks Sarge); PIAA 24" wiper blades; updated EGR valve; BriteBox; Re-flashed; Fuel Pressure gauge; DashDaq on deck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
