Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
C750 brakes and clutch
Old 05-19-2022, 04:07 PM
Cascadia F750's Avatar
Cascadia F750
Cascadia F750 is offline
4wd Low
Just picked up my 69 750 COBreaks don't work and clutch slave is leaking
Where do I get new Master cylinder for breaks and clutch?
Old 05-19-2022, 05:31 PM
abe's Avatar
abe
abe is online now
One Meadow Green Owner
Received 2,597 Likes on 1,443 Posts
I check NAPA.
But you may want to ask this to the 67-72 Bumpside forum. This is the 48-56 forum
(Moderator note: thread moved)
Old 05-19-2022, 08:59 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,579 Likes on 1,288 Posts
Welcome to FTE!
I moved you to Large Truck as that's where you will find other owners of trucks your size.
The C series have vertical mounted master cylinders. You have to fill them from the top by pulling back the rubber dust covers where the rods go in.
You should also have a remote hydro vac brake booster that provides the power assist.
NAPA may have parts, but you have to change the vehicle type to "Medium Heavy". I tried finding a clutch slave for a '69 C750, no luck.
Post 2 has an illustration of the clutch hydraulics. Post 4 has the part number for a clutch master repair kit and some sources. Since it was a 2019 post, hard to say if they would have any. They may have other parts you need:
https://www.ford-trucks.com/forums/1...l#post18858927
Another source found by searching for the part number listed in that post:
https://nospartsltd.com/product/b8t7578a/
More of the same--BTW, what engine do you have?
https://www.ford-trucks.com/forums/1...l#post17177313
https://www.ford-trucks.com/forums/1...l#post19521719
How to add fluid and bleed:
https://www.ford-trucks.com/forums/1...l#post16971315
Brakes: Have you checked fluid, checked all lines, master, booster, wheel cylinders for leaks?
Brake drums are not available. All the rest is, but it takes some searching.
The following users liked this post:
Old 05-28-2022, 02:01 AM
Anoymousjoe4126's Avatar
Anoymousjoe4126
Anoymousjoe4126 is offline
Brake drums ARE available for DAYTON (drop center hubs) with air brakes. They just need cut down to the right width on a lathe or mill. That is what I had to do. Advanced auto part number for the drums I used # 52230-10 16.5x7". I am also having 16.5x7" brake shoes cut down to size after giving up of finding a decent brake shop by me. Thankfully my F700 has air brakes. Long story short if you are creative there are solutions for "impossible" parts. Good luck.
Old 05-28-2022, 10:38 AM
Cascadia F750
4wd Low
So I went a different route and hired a mechanic. I live next to Port of Tacoma so plenty to chose from. He bought the clutch slave and the break booster but the master cylinder is out 4weeks. He is going to flush all of the lines and change at least one seal on the rear passenger side.
I feel better hiring this out as I don't have time and the mechanic I chose has plenty of experience working on farm trucks. And he loves this truck as much as me. I'm going to pass some of this info on to him though.
Cheers
Old 05-28-2022, 10:42 AM
Cascadia F750
4wd Low
Originally Posted by 85e150
Welcome to FTE!
I believe it is a 366 gaser
Old 05-28-2022, 06:42 PM
85e150's Avatar
85e150
If you post a picture of the warranty plate on the driver's door, we can see what it came with as OEM.
A 366 is a Chevy truck engine. Your truck would have come with a 330, 361 or 391 as gas V8s. SD V8s might have been an option too, but I'm not sure.
Old 05-28-2022, 09:35 PM
third66go's Avatar
third66go
third66go is offline
If your mechanic doesn't know already, Brake and Clutch Supply in South Seattle has or can find/repair wheel/brake/axle/steer/suspension parts for old trucks - ask for Sparks
The following 2 users liked this post by third66go:
Old 05-29-2022, 01:10 AM
Cascadia F750
4wd Low
I think this is that plate
Old 05-29-2022, 05:56 PM
85e150's Avatar
85e150
That's the one:
C75 = C750
M? W? Can you clarify this digit? This is the engine code and M & W are diesel engine codes for your year. BUT the Certified Net HP of 182 @ 3800 is the number for a 361 gas engine. See below.
U = Louisville Assembly Plant
F14327 = 1969 numerical series, May 1969 production date.
135 = 135 inch wheelbase
J = Red
C750 = C750, 24,000 lbs GVWR
1291 = Standard cab. I do not have the upholstery or interior info.
M = Clark model 285V five speed direct transmission
E3D
E3 = Eaton model 16244 Two Speed Rear Axle / 6.50/9.04 / 17,500 lbs. Rear Axle Capacity.
D = Ford-Rockwell/Timken 7,000 lbs. Capacity Front Axle.
24000 = 24,000 lbs GVWR
182 3800 = 182 certified net HP @ 3800 RPM (see above about engine code)
440507
44 = Twin Cities District Sales Office
0507 = Special Order Number
This thread decodes another C series with the W code but the 361 power numbers. There's another one, maybe more here as well:
https://www.ford-trucks.com/forums/1...l#post19508405
I can't find power figures on the Dorset engines, but I'm pretty sure it wouldn't be 182 @ 3800. Nor would a truck equipped with one of those have the axle ratios shown above.
But you noted already you have a gas engine, so it's probably a safe bet that you have a 361 FT.
Note also your truck was a special order. Unknown what that might be.
It looks like you might have Dayton style wheels? The ones with the big 5 spoke centers? If so, good, you dodged the widowmakers.
Old 05-30-2022, 02:50 PM
third66go's Avatar
third66go
W also decodes to 361-2V/LPG Propane...but it looks like a gasoline "step tank" behind the wheel, which is curious because a step there goes nowhere, so maybe it was converted from LPG to gas with a tank that was available at the time of conversion?? Is it running on gasoline now?
The 69 shop manual does not cover LPG systems, so was the truck built as a gasser and then shipped to a conversion facility? Could that be a DSO order? Just speculating - anybody know?
Old 05-31-2022, 12:15 AM
85e150's Avatar
85e150
Originally Posted by third66go
W also decodes to 361-2V/LPG Propane..................
I find that in the '73-'79 MPC, but no mention of propane in the '64-'72 MPC. Since this is a '69 it wouldn't apply.
In the '64-'72 MPC, there is no code for a DSO engine. In the '73-'79 MPC, there are multiple references to DSO for several engines. Detroits, Cats, Cummins, several propane models including the 361 4V & 2V.
As far as anyone who would know, see the link in post 10 to the Numberdummy decode of a '70 C series with this engine code.
Old 05-31-2022, 09:50 AM
Cascadia F750
4wd Low
M=5 speed. It is a five speed
Are these Dayton's The step on the fuel tank might have been it's first life as a fuel truck
Old 05-31-2022, 01:44 PM
85e150's Avatar
85e150
Yes those are Dayton type. There are a couple or more makers of that type wheel.
Old 05-31-2022, 02:22 PM
third66go's Avatar
third66go
From the Jan '69 Maintenance Manual, first Heavy/Extra Heavy box...
And I just noticed in the "Perfect C-series " thread, there is an advertisement about the option, just can't figure out if this was done on the assembly line or done at an upfitter later
Quick Reply: C750 brakes and clutch
