Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-19-2009, 11:45 AM
FLATFORD1976's Avatar
FLATFORD1976 FLATFORD1976 is offline
FLATFORD1976 is starting off with a positive reputation.
360 cam and headers
whats up guys I have a 76 w/ a 360. I am on a budget and I have already installed a edelbrock intake and 600 carb and I was wondering how much difference i am going to notice if I install a high performace cam and a set of headers on an otherwise stock motor. Will it be worth my time and $$$$$.
__________________
"If it was easy everyone would do it"
"You can't argue with RESULTS"
"Doing STUFF on the CHEAP =CHEAP STUFF"
  #2 (permalink)
Old 10-19-2009, 02:52 PM
Bear 45/70's Avatar
Bear 45/70 Bear 45/70 is online now
Bear 45/70 has a good reputation on FTE. Bear 45/70 has a good reputation on FTE.
Without a compression increase and a cam to take advantage of the headers, intake and carb, you are throwing your money away. Better yet either find a 390 or convert your engine to a 390. The difference is night and day. Then your intake, carb and headers will have something to work with.
__________________
Bear 45/70 Gimp Racing <a href=http://i145.photobucket.com/albums/r206/Bear-45-70/Emoticons/icon_weelchairbb.gif target=_blank>http://i145.photobucket.com/albums/r...eelchairbb.gif</a>
“There are only two things stopping you, common sense and fear! And not much of the latter.”
  #3 (permalink)
Old 10-20-2009, 09:52 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
For a little bit of a kick, put a pre-72 timing set in it. The cam timing is way off on the 1972-and-up 360's. That is, if someone else hasn't already done it.
The real question is, looking at that motor, has anyone already done work to it, and possibly put different pistons in it?
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #4 (permalink)
Old 10-20-2009, 06:48 PM
I dressed the motor up myself...It came out of a junkyard truck.Now what has been done to it I don't know.
when did ford start using the fe family I know they stopped in 76.
I also need a timing cover any help on that
__________________
  #5 (permalink)
Old 10-20-2009, 07:06 PM
Bear 45/70's Avatar
Quote:
Originally Posted by flatford1976 View Post
i dressed the motor up myself...it came out of a junkyard truck.now what has been done to it i don't know.
When did ford start using the fe family i know they stopped in 76.
*****1958******
__________________
  #6 (permalink)
Old 10-20-2009, 07:17 PM
MeanGene427 MeanGene427 is offline
MeanGene427 is starting off with a positive reputation.
If you were to go with headers 'n cam, a short-duration, high lift deal with a non-smog straight up timing set would help pump up the dynamic compression and make quite a difference- if you run much duration at all, it just makes the low-compression engine that much more breathless- so don't expect to have both power and a rumpty-rump sound, a long cam will give it more athsma
  #7 (permalink)
Old 10-20-2009, 09:10 PM
Kennewick's Avatar
Kennewick Kennewick is offline
Kennewick is starting off with a positive reputation.
I think with a 360 your better off controlling the backpressure for tourque, Straight up time set from cloyes is cheap. Then not too much carb and not too much exhaust paying attention to exhaust pipe size. You would be better off with a smaller carb and good 4 hole spacer. But if you have too much carb a open spacer will tame it down. The spacer will actually increase the flow as the carefully sized exhaust draws air all the way from the carb to the tail pipe (scavange). It will not be a 390 but you can get nice performance out of it and much better gas mileage. I have the new pertronix 3 and it made a big differance also. It sounds good too.
Any way it's what I found. Here is some 360 home work................................
http://www.ford-trucks.com/forums/88...time-sets.html
http://www.popularhotrodding.com/buy...wer/index.html
http://www.qsl.net/ya5t/pipes.htm
http://www.broaderperformance.com/mu...flow_tests.htm
You can't work a 360 like a 390. By the way my last MPG which was mostly interstate (75 to 80) and some punching around town not being careful was just over 15mpg. But I stayed with the stock Ex manis, still had the 2100 1.21v carb with tall 2 hole spacer, striaght up timeset, 2.25" primary pipe to the H pipe (2") then 2.5 inch glass packs with 2" tailpipes behind the rear tires dual exhaust. I also have a real cold air intake. I am adding a 2v 1.33v 2100 and taller spacer.
  #8 (permalink)
Old 10-21-2009, 11:06 AM
Krewat's Avatar
I don't know about backpressure with the 360 - I had a stock one with 1 7/8" long-tube headers on it, with a very unrestrictive dual exhaust, and it had plenty of torque.
__________________
  #9 (permalink)
Old 10-21-2009, 10:09 PM
Kennewick's Avatar
Quote:
Sometimes I run off at the mouth
  #10 (permalink)
Old 10-21-2009, 10:27 PM
Redmanbob's Avatar
Redmanbob Redmanbob is online now
FE Pwrd F100 RaciN-waNabe
1964 Ford F-100
My Garage
Redmanbob is gaining momentum as a positive member of FTE. Redmanbob is gaining momentum as a positive member of FTE.
Difference, yes. Your wallet will weigh less and your hands will be dirty.
__________________
66 F100 352FE / Cruiso
64 F100 352FE / T-98
"Po-Dunk Redkneck Transplant"
CRATE = Cant Really Appreciate The Engine..
http://www.ford-trucks.com/forums/61...vs-west-3.html
http://www.youtube.com/watch?v=1nX38wamqwY
  #11 (permalink)
Old 10-26-2009, 12:14 AM
Quote:
LOL that is true but my wallet is always light and my hands are always dirty so it might not be that much of a difference lol
__________________
  #12 (permalink)
Old 11-01-2009, 10:23 AM
Kennewick's Avatar
What did you decide for your build?
  #13 (permalink)
Old 11-11-2009, 11:50 PM
Alvin in AZ Alvin in AZ is offline
Alvin in AZ is gaining momentum as a positive member of FTE.
I chose the Comp 252/252 straight up.
(didn't know nuthin', hmmm... still don't)
How does the 252/252 compare to what you have in mind?
Which Comp cam would choose to do what you talk about there? :)
Anybody?
Alvin in AZ
  #14 (permalink)
Old 11-12-2009, 12:39 AM
Kennewick's Avatar
Anybody?
Alvin in AZ
I think he was saying a 360 only has lungs that are so big. Pushing more than it can breath drops the little bit of compression thats left, droping all the power. 360's seem to run better with the stock or close to stock equipment. A bigger cam will give you lumpity lump and big pipes will sound loud and mean but at a price. A 600 cfm 4 barrel can flow enough for a 300 hp+ motor 2 1/4" exhaust pipes can flow enough for up to a 300 hp motor. At best with careful application you may get 250hp out of a 360 but a nice 250 with high torque at low rpm. Add a nice ignition,
A stock cam, straight up time set, careful exhaust to maintain that dynamic compression Gene was talkin about and a carb sized for the airflow range your working with and you have what it's got. But in a rig like yours nice and cool lookin. I am not railing you at all what you pick works for you. I admire the work your putting into it and can't wait to see the color you pick. My vote was a real pro flat black job. Good job!
Good luck!
Oh and PS all this is just my "opinion" others are sharper than me.
  #15 (permalink)
Old 11-15-2009, 01:16 AM
Kennewick's Avatar
Not sure if this thread will go anywhere but you may want to track this one. Perhaps a higher compression ratio solution for your 360 mabey not.
http://www.ford-trucks.com/forums/90...0-pistons.html
Tags
360 , 390 , cam , camshaft , ford , headders , headers , timing , truck , v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
