Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 and Newer F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
The 2009 and Newer F150 Discuss the new 2009, 2010 Ford F150 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-19-2009, 11:10 AM
ford_07 ford_07 is offline
ford_07 is starting off with a positive reputation.
First tow... now im impressed
i hooked a load behind my truck for the first time this weekend
and let me say any douts i had about buying a half ton with
a gas engine have been taken care of.
i was towing a 22ft flat deck tandem axel trailer (hydraulic tilt deck which adds a little extra weight to the trailer), round trip was about 150miles, i loaded up 10 round bails (approx 1000lbs each) some might say thats crazy but i felt in control the entire time and the truck handled it considerable well. and i realize this is pushing the limits but wow... there was one 9% grade that i climbed, i just came off a ferry so there was no room to get a run at the hill and the truck shifted through the gears until it found one it could pull the hill in. i belive it was 3rd gear, and i gained speed up to the 50mph speed limit when i backed off the throttle a little bit until we went over the top. i was in tow/haul the whole time i was loaded. the trailer brake controller once set worked flawlessly.
now dont get me wrong i would not want to pull this kind of load all day every day but once in a while this truck is more than capable for whatever i might throw at it.
empty trailer-13.6 average mpg
loaded trailer- 7.4 average mpg
  #2 (permalink)
Old 10-19-2009, 10:18 PM
Deluxe05's Avatar
Deluxe05 Deluxe05 is offline
Deluxe05 has a very good reputation on FTE. Deluxe05 has a very good reputation on FTE. Deluxe05 has a very good reputation on FTE. Deluxe05 has a very good reputation on FTE.
Glad to hear that you have a new found respect for your truck. They are quite capable, and in working conditions, they definitely give us a reminder of why the F-Series has been the #1 seller for so long!!
__________________
Semper Fi
"Some people live an entire lifetime and wonder if they have made a difference in the world. Marines don't have that problem." - Ronald Reagan
  #3 (permalink)
Old 10-20-2009, 10:19 AM
you got that right, i looked over the competions trucks before i bought this one and IMO there is no comparison!
  #4 (permalink)
Old 10-20-2009, 08:25 PM
Greg B Greg B is offline
Greg B is starting off with a positive reputation.
There might be a few that may have a feature or two better like engine, but nobody builds the complete performance package that Ford does.
  #5 (permalink)
Old 10-21-2009, 07:06 AM
m350 m350 is offline
m350 is starting off with a positive reputation.
Thats a pretty impressive load for an F-150 !!,,,my 16', 4 ton Equipment trailer weighs around 1800 lbs empty,,,,so your 22',,Hyd tilt deck has to weigh atleast 2500 lbs or so,,,plus 10,000 in Hay bales,,,wow,,,stout F-150's !
__________________
06' F-350 XLT SC, S-Bed, 6.0, Auto, man-hubs
04' Explorer NBX, 4.6, auto, 3:73 LS
68' Torino, 289, 4 gear
  #6 (permalink)
Old 10-21-2009, 10:38 AM
thats about what we were thinking, i borrowed the trailer from my uncle so i havent actually weighed it.
  #7 (permalink)
Old 11-02-2009, 04:35 PM
speedster1322 speedster1322 is offline
speedster1322 is starting off with a positive reputation.
So I am new here and just purchased and 09 Platinum. The weight you describe is 10K lbs plus the trailer. What do you feel is the max towing capacity is for our trucks?
I have a 31ft Cedar Creek travel trailer that I pull about 2 times per year and just want to make sure that the Capacity will be OK. I had an 04 F150 prior that I used and it seemed OK.
  #8 (permalink)
Old 11-02-2009, 07:09 PM
broncobran68's Avatar
broncobran68 broncobran68 is offline
2009 Ford F-150
broncobran68 is starting off with a positive reputation.
Quote:
That is a complicated question. Around the farm you can pull as much as the truck can handle. 20k, 30k whatever you have the torque and traction for.
However I would be hesistant to regularly pull near the trucks rated limit of 11.1k or 11.3k, especially at interstate speeds or over challenging mountain passes that require heavy braking, steering, or throttle input.
But if you tow slow, a couple times a year, over moderate terrain, then your F150 can really handle some weight. If your 04 did it, your 09 will do it better.
__________________
'09 F150 SCREW FX4. 2.5" AS Leveling kit. Line-x. 35" Toyo M/Ts on 18x9 Moto Metals
'68 BRONCO. 5.5" lift, 35s, 289 EFI, rollcage, durabak interior
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
