Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-19-2009, 10:09 AM
topdrive topdrive is offline
topdrive is starting off with a positive reputation.
checked my fuel pressure
hey guys after reading quite a few posts about fuel pressure i decided to check mine. I rigged up a guage and found i have 50psi at idle i got a buddy to rev it up to 3000rpm and i still had 50psi does this seem normal to you guys to me its a little on the low side. Im just wondering if shimming the regulator would boost it up a little bit. (ps if anyone is looking for the m12x1.5 fitting i found mine at a hydraulic shop i went with a m12x1.5 to a #4 jic fitting and used hydraulic hose to the guage)
__________________
2003 f-350 super duty 6.0l autometer phantom (pyro,boost,tranny),arp studs,liberator egr delete,no tuning (saving for a sct) dual steering stabilizers 285/75/16 hankook dynapro atms,billet grille,brite box,alpine jl audio sounds stock exhaust(kitty ran away) a whole lot more planned 340000km and running strong
  #2 (permalink)
Old 10-19-2009, 10:22 AM
69cj 69cj is offline
69cj has a good reputation on FTE. 69cj has a good reputation on FTE.
45 + at WOT is good. You need to be under load at WOT as in driving the truck.
__________________
"05 F-250, 6.0, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, Magnefine p.s. filter, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
173rd Abn.
  #3 (permalink)
Old 10-19-2009, 10:34 AM
so if im only getting 50psi at an idle theres a good chance at wot i am going to be under 45psi i will have to make my hose longer and check it at wot
__________________
  #4 (permalink)
Old 10-19-2009, 10:53 AM
tex25025's Avatar
tex25025 tex25025 is offline
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
Yes, there is a chance. I know I was reading about 50 during normal driving, but when I was asking for it to move and move quickly it dropped down to 20 real quick. Now it did bounce back as soon as I let off the throttle, but the fact that it took a nose dive made me upgrade my pump real quick.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Spartan Stage 1 Towing Injectors
Spartan 64mm Non-VGT Turbo
Fluidampner
Headstuds
Beta Spartan Phalanx
Fuel Regulated Return
FASS 150/180
Suncoast Heavy Duty Torqshift Rebuild
5" Straight-Piped MBRP Exhaust
Tranny, EGT, Boost, and Fuel PSI C2 Gauges
Water Temp, Oil PSI, Volts Antique Beige Gauges
  #5 (permalink)
Old 10-19-2009, 11:04 AM
adambomb's Avatar
adambomb adambomb is offline
2005 Ford F-350
adambomb is gaining momentum as a positive member of FTE. adambomb is gaining momentum as a positive member of FTE.
i've been wanting to check my fuel pressure too. i see the fitting you used, what gauge did you use?
__________________
2005 F350 6.0L Lariat FX4 Crew Cab Long Bed
*Industrial Injection Hybrid Turbo*90hp DDP Injectors*SCT X3*ARP Studs/Stock Gaskets*Banks Techni-Cooler*FASS Fuel System*AFE Intake*4" MBRP Turbo Back Exhaust*DieselTech1.com EGR*AutoMeter PhantomII Boost/Pyro/Trans Gauges*2.5" ICON Suspension*35" Xtreme AT's*18" KMC Monsters*AMP Research Steps*Pioneer AVIC N3 Nav-Rear Camera-iPod*
  #6 (permalink)
Old 10-19-2009, 10:12 PM
I just used a 200psi nuview guage i got it at the same place i got the fitting. I checked it at wot today and it would drop to 35 when i stepped on it. I stretched the spring an 1/8 of an inch and got it to 57psi at an idle and 40 at wot. Whats next i am on a pretty small budget right now but i cant keep driving like this.
__________________
  #7 (permalink)
Old 10-19-2009, 10:56 PM
cheezit cheezit is offline
cheezit is gaining momentum as a positive member of FTE.
there is a new regulator base p/n# 9t517 and it seems to give a few extra pounds. also I have rune into filters that are new aftermarket that are causing restriction problems. Imo try a oem filter kit and the new 9t517
  #8 (permalink)
Old 10-19-2009, 11:01 PM
i ll have to try the 9t517 is that just a different spring or whole new piece also i run nothing but oem filters and i just changed them 500km ago
__________________
  #9 (permalink)
Old 10-19-2009, 11:03 PM
thats a whole kit comes with 0-rings, brass sleve and and regulator cover. make shure you put the bevel oring on the right direction. the bevel goes in and sits in the cutout grove in the brass plunger
  #10 (permalink)
Old 10-20-2009, 10:18 AM
Culvert Culvert is offline
Culvert is starting off with a positive reputation.
subscribing to thread. pressure gauge adaptor on order.
__________________
06 F350 6.0L CC FX4
01 Windstar Sport
66 Fairlane 500XL
  #11 (permalink)
Old 11-06-2009, 09:38 PM
desertt5 desertt5 is offline
2003 Ford Excursion
desertt5 is starting off with a positive reputation.
Great info
__________________
03 Ex Limited 6.0 4x4
09 KZ Spree 289KS
Semper Fi
Tags
05 , 2003 , 60 , check , checking , f250 , f350 , ford , fuel , kitty , low , normal , powerstroke , pressure , ran , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
