Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-19-2009, 07:36 AM
Copedawg's Avatar
Copedawg Copedawg is offline
Copedawg is gaining momentum as a positive member of FTE.
Having a problem with a sh sh Chevy
Maybe you all can give me hand w/a GM thats running hot/overheating. I have looked in other forums but they are as helpfull as a fly in labor! My buddy has a 1989 Olds 98 V6 200K It is running hot and has overheated 1nce. We replaced the thermostat and cap and fixed a leak in the overflow tank. It still runs hot 200+*. Everything else seems to be working, what am I missing?
__________________
97 F350 7.3L Auto 4WD Crew Cab 200K (Cali model bummer). Another OFFICIAL six point slow recovery vehicle! MODS: HOOOOGA! horn, 6637, Service/Utility bed, 3" DP, Testing that Cat, 120v IDM (for now), 2 10K pots. US ARMY OAS, OJE-IFOR, SFOR,2,5, OJG-KFOR, OIF, OEF. To ALL that have served, THANK YOU!
  #2 (permalink)
Old 10-19-2009, 09:16 AM
Talyn's Avatar
Talyn Talyn is offline
Midnight Mods
1994 Ford F-250
Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE.
Test the coolant?
Is there Bar's leak in there?
if the radiator has slime inside it, it will not cool either.
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 F250 XLT 4x4 Standard Cab - T-444E Direct Injection Turbo Diesel, ZF-5.
Rosewood Stage 1's, PHP Tuner, 6637, Short Throw Shift Kit, Valair Kevlar/Ceramic.
Midwest Shift Kit - http://www.midnightmods.com/2009/11/...ifter-kit.html
Quote:
Originally Posted by Riffraff Performance
I want chimichangas
  #3 (permalink)
Old 10-19-2009, 09:35 AM
Copedawg's Avatar
Thanks Talyn. The coolant looks good. The thermostat opens around 190+ ish (I think). The top hose get hard and hot when the thermos opens, then cools down and and gets squishy when it closes. The fan (electric) runs OK and seems to cool it down to 190 something. This all started when it overheated. I noticed the overflow bottle was cracked I fixed it with some epoxy. I thought that would fix the running hot problem but it didn't. So we replaced the thermostat and cap and still no help. I spose we will look at the coolant and see if it os OK with a tester but I don't think it is the problem. There me be another valve or something that I am not seeing. The blows good and hot. Any other suggestions?
__________________
  #4 (permalink)
Old 10-19-2009, 10:15 AM
MADVAN's Avatar
MADVAN MADVAN is offline
MADVAN has a good reputation on FTE. MADVAN has a good reputation on FTE.
Pressure test the coolant cold then hot. See if it holds.
Could be a head gasket.
Bill
__________________
97 4X4 PSD Quigley
  #5 (permalink)
Old 10-19-2009, 12:09 PM
Copedawg's Avatar
We are going to start on this project back up later in the week. I will get a pressure tester from work and see what happens. I assume if it looses pressure with no leaks a head gasket may be bad? I hope not. I am also going to get a infared laser tester and test the temp at the thermostat. This particular vehicle ALL digital, not 1 knob on the whole dashboard. I have some more places to look now.
Thanks!
__________________
  #6 (permalink)
Old 10-19-2009, 04:19 PM
Talyn's Avatar
Midnight Mods
1994 Ford F-250
The reason I said test the coolant is, I never knew this till yesterday, but too much water or too much antifreeze and you loose effectivness eitherway.
__________________
I want chimichangas
  #7 (permalink)
Old 10-19-2009, 04:26 PM
Copedawg's Avatar
From what understand about the mixture is: Too much antifreeze will not conduct enough heat to the surface areas to help dissipate the heat (straight antifreeze will cause overheating). Too much water and well, it will freeze (32* and water will freeze). I am old enough to know I don't know chit. Is this right?
I think we will start with that. Drain it and mix it right/screw the testing. Thanks Talyn!
__________________
  #8 (permalink)
Old 10-19-2009, 05:19 PM
Talyn's Avatar
Midnight Mods
1994 Ford F-250
probably needs a good cleaning inside.
__________________
I want chimichangas
  #9 (permalink)
Old 10-19-2009, 05:57 PM
arkredneck arkredneck is offline
arkredneck is starting off with a positive reputation.
is all the air out of the system some of those v6 engines had air bleed screws?
  #10 (permalink)
Old 10-19-2009, 06:30 PM
427 fordman 427 fordman is offline
427 fordman is gaining momentum as a positive member of FTE.
Its a GM. What do you expect? Tell him to trade for a ford. imho
__________________
Darin I BLEED BLUE 76F250 66 fairlane dragcar514
1997 F250 HD 7.3,140VIDM,HPX, 3-4"dp, rosewood stage ones,php,6.0IC,trucool,guages,racer x valve body-- ebpv cat muff gone
  #11 (permalink)
Old 10-19-2009, 06:34 PM
Copedawg's Avatar
He has a 97 Ranger....but he is also a Dallas fan go figure!? But he is still my buddy and I have to help him out, lol
__________________
  #12 (permalink)
Old 10-19-2009, 06:35 PM
Copedawg's Avatar
I will look for some air screws/bleeders but I think Talyn could be right/just bad mixture, we'll see
__________________
  #13 (permalink)
Old 10-19-2009, 06:41 PM
I understand completely. Just giving crap. Does he ever lose water or just get hot? If he does and it isn't going in the oil could it be a head gasket from when it overheated before leaking into the exhaust?
__________________
  #14 (permalink)
Old 10-19-2009, 06:49 PM
Copedawg's Avatar
He hasn't lost water since we repaired the overflow tank. No "chocolate milk" in the oil, no "steamy exhaust" . still has the same amount of coolant.
I hate to bring a GM in this fine forum but I can't get answers or even responses anywhere else. I appreciate everyones input! I just want to make sure I am not missing anything obvious.
__________________
  #15 (permalink)
Old 10-19-2009, 10:43 PM
helifixer's Avatar
helifixer helifixer is offline
Rest in Peace Jake
helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold helifixer is a splendid one to behold
don't rule out a bad thermostat, I am on my 4 th one in my service truck in less than a month. one stuck open one stuck shut one ran hot.
most gm V6 engines have bleed screws on the coolant system, if not bleed the system will vapor lock.
as far as a perfect mixture of anti freeze it isn't totally critical, maybe a few degrees?
I would run strait water until I found the problem unless it is going below freezing at night and the car has to be outside.
I would also buy a flush "T" and flush the system!
I also would NOT replace the DEX-COOL, it is corrosive and there is a lot of aluminum (this from a gm tech and my cousin who was a pontiac tech)
__________________
They promise freedom, but they themselves are slaves of sin and corruption. For you are a slave to whatever controls you.
the little people who live behind my eyes and scream directly at my brain told me to tell you HELLO
Diamond K your complete automotive and truck repair center
Tags
89 , bleed , chevy , radiator , screws , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
