Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Georgia Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Georgia Chapter Join Chapter, Leader: ChiefM SPONSORED BY:
  #1 (permalink)
Old 11-07-2002, 06:17 PM
jim dog jim dog is offline
Garage is empty, add now
jim dog is starting off with a positive reputation.
Post 1988 150 lariat fuel problem
i have been having a problem with the fuel system in my truck./
a little history
the truck had been setting for about year
had to replace clutch
then i had to replace tank and front fuel pump
ran for about month then it quit on my son and he had it towed to a place in orangeburg, my wife spent $500 on replaceing the same fuel pump that i had just put on.
well they drove it back to elko and it quit running again.
when i got home i picked it up where they left it and it cranked right up, i started to drive it back home and it start sputering,coughing and basicly quit, it started back up about 5 minutes later and i drove it maybe 3 miles and it starting missing again, as long as i was pumping the peddle it would start again i finally got it home and thats where it is setting now.
i'm not much on fuel systems as this problems seems to be.
any input would be appreciated.
thanks
jim in elko
  #2 (permalink)
Old 11-10-2002, 06:54 AM
bmoran bmoran is offline
bmoran is starting off with a positive reputation.
Jim,
You might want to try changing the "sock" in the fuel tank. It's at the suction end of the tube in the bottom of the tank and when they clog it gives you the symptoms that you describe. If they didn't change it when they changed the tank it's probably clogged with rust, etc..
Unfortunately, this can drive you nuts trying to find. About the only way to do it is to get a fuel pressure gage and drive the truck with the pressure gage hooked up and watch it when the truck starts to run poorly. If the fuel pressure is dropping, then you have a problem in the fuel delivery and since you have replaced most of the other pieces, this could be the issue.
Bill
__________________
Bill
66 F100
5.0 FI w/AOD
PS, PDB, Tilt, etc.
  #3 (permalink)
Old 11-17-2002, 08:03 PM
Brett200 Brett200 is offline
Brett200 is starting off with a positive reputation.
Tags
1988, ford, fuel, lariat, pump
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
