Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 10-18-2009, 05:41 PM
3BadBirds 3BadBirds is offline
Garage is empty, add now
3BadBirds is starting off with a positive reputation.
Question 88 F250 Wiper Motor Removal Question
After many years of groaning, I think my wiper motor has finally bit the dust. Now when I turn it on (at any speed) I just hear the breaker in the wiper switch clicking away. I know when I have replaced motors on other trucks and cars, I was often able to just unbolt the motor to get enough clearance to uncouple the transmission linkage. Has anyone tried this before on their 88 F250, and can you tell me if it’s a nut or a clip I should be looking for? I’m hoping to avoid having to remove the cowl to gain access.
Thanks
  #2 (permalink)
Old 10-18-2009, 06:20 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel is gaining momentum as a positive member of FTE.Blue Rebel is gaining momentum as a positive member of FTE.
its a clip, good luck doing it without taking the cowl off.
BTW, why dont you want to remove the cowl? Its only like 10 screws and it comes right off...
__________________
1989 F250 4x4, 351W, ZF S542, 4:10s, Upgraded to Dana 50 TTB front, 4" suspension lift 33" street, 38" swampers for when things get crazy!
1995 F150 4x4 Swapped in 351W MAF, 4r70w auto, 6" suspension lift, 35" tires, 4:10s, Daily Driver
1993 F350 4x4, 7.3L N/A, ZF S547, 4:10s
  #3 (permalink)
Old 10-18-2009, 06:41 PM
BearFootCustom's Avatar
BearFootCustom BearFootCustom is offline
BearFootCustom is starting off with a positive reputation.
Take the cowel off and you can replace the motor in seconds. Or you can fight with it for a couple hours and not take it off.
__________________
1993 F250 XLT 460 5 speed D60 RSK
2002 VW Passat 4motion DD
1978 F150 Custom 460
  #4 (permalink)
Old 10-18-2009, 07:22 PM
I’m a little apprehensive about messing with the cowl because my truck was repainted before I got it (not the best of jobs) and I’m not sure how well this piece will “separate” from the rest of the body without damaging the paint. Also, don’t you have to remove the windshield trim to get to some of the screws? I’ve never had this trim off before but it looks like someone had used some sealant around a lot of it. I figured that might be another can or worms.
Its not that I’m really against removing the cowl. I just figured that if I can disconnect the motor without messing with it, why not. That’s why I figured I checked in with the group first.
Thanks!
  #5 (permalink)
Old 10-18-2009, 07:46 PM
Blue Rebel's Avatar
Nope, the only screws holding the cowl down are the ones you see from up top, and on the lip by the hood. the cowl slides under the windshield trim, nothing holds it down from under there.
__________________
  #6 (permalink)
Old 10-18-2009, 08:54 PM
MrRogers's Avatar
MrRogers MrRogers is offline
1990 Ford F-150
MrRogers is starting off with a positive reputation.
if you are afraid about the paint, just take a utility knife and score it. If it's gonna flake, that should contain it. Then touch up paint is your best friend when you reinstall. Done this multiple times and always had great luck.
__________________
Black 1990 F150 302 2wd
  #7 (permalink)
Old 10-19-2009, 06:46 AM
Thanks for the info! Not having to remove the trim is certainly good news.
I'll take a look and report back!
Thanks again for the help!
  #8 (permalink)
Old 10-20-2009, 04:52 PM
You guys were right. It would have been a nitemare trying to get that motor / clip out without first removing the cowl.
Now that I have it out and all the arms disconnected, is there any particular procedure for reinstalling everything? I didn’t know if they should be a particular position before I connect them to the motor and don’t want a jam. I was just going to fasten them and then put the arms back on after the motor parks.
  #9 (permalink)
Old 10-20-2009, 07:30 PM
Volvo92906's Avatar
Volvo92906 Volvo92906 is offline
1988 Ford F-150
Volvo92906 is gaining momentum as a positive member of FTE.
If the wiper motor is in the same position for the arms to work properly, all you need to do is bolt on the new one and plug everything up. Its not anything to worry about. Dont overthink it.
__________________
en·gine noun -a machine for converting thermal energy into mechanical energy or power to produce force and motion.
mo·tor noun -a machine that converts electrical energy into mechanical energy, as an induction motor.
  #10 (permalink)
Old 10-20-2009, 08:11 PM
I had to remove the bracket and arm that was attached to the old motor to use on the new. The shaft on the motor is sloted so the arm can be mounted in two different directions and I don't remember how it came off. Guess it doesn't matter....
Cheers!
  #11 (permalink)
Old 10-21-2009, 05:10 AM
Volvo92906's Avatar
1988 Ford F-150
Turn the new motor on and park it. Then hook up the wiper arms in the parked position. No problem.
__________________
Tags
1989, 1990, 89, f150, f250, ford, fordtruckmotorremoval, motor, pick, pickup, removal, remove, replace, replacing, windshield, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
