Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-18-2009, 05:18 PM
rbig1 rbig1 is offline
rbig1 is starting off with a positive reputation.
air bags in truck
well i put my bags in today. bottom bracket looks plain but have to mount panhard to something. welded up to step notch well. have to add to pan hard and build bracket for one end. found mfg bags extended length was 3/4" shorter than stated travel is 4" flat 10 1/4 fullparty photos in bucket
  #2 (permalink)
Old 10-18-2009, 10:04 PM
rtcalabrojr's Avatar
rtcalabrojr rtcalabrojr is offline
rtcalabrojr is starting off with a positive reputation.
Wheres the photos?
__________________
Roger
1955 F100
I smell cookies! click to check out the truck
http://s919.photobucket.com/albums/ad37/rtcalabrojr/
  #3 (permalink)
Old 10-18-2009, 10:19 PM
sorry the pictures are at http://s572.photobucket.com/albums/ss170/rbig1/
  #4 (permalink)
Old 10-18-2009, 10:32 PM
sdetweil's Avatar
sdetweil sdetweil is offline
1955 Ford F-100
sdetweil is gaining momentum as a positive member of FTE. sdetweil is gaining momentum as a positive member of FTE.
you should add a small wedge to each side of the bag bracket off the axle tube, to reinforce the bracket.. amazing how much pressure will be put on this
cantilever.. can't draw..
Sam
__________________
55 F100 460/c6, 3.55ls
08 F350 4x2, DRW, CC, LB
  #5 (permalink)
Old 10-18-2009, 10:39 PM
looking good! You pumkin is in the center of your axle mine is off set to the pass side. Thats whats giving me a problem.
__________________
Roger
1955 F100
  #6 (permalink)
Old 10-18-2009, 10:43 PM
ya i definetly need support i put 330lb jumping up and down it was flexing on lower end
  #7 (permalink)
Old 10-18-2009, 10:55 PM
how much room do you have on that side i hope about 4" i had to notch the inside of the lower plate for the casting i only used a 1/2"relief you might have to run a small bracket underside for strength
  #8 (permalink)
Old 10-18-2009, 11:00 PM
i might just have 4"?
Photobucket
__________________
Roger
1955 F100
  #9 (permalink)
Old 10-18-2009, 11:08 PM
you might make a mock up mount before you cut on that nice bracket you have. and see what it would look like. i did mine twice before i did it that way. not much help for you but first time for me.
  #10 (permalink)
Old 10-18-2009, 11:13 PM
How long of a panhard are you using?
__________________
Roger
1955 F100
  #11 (permalink)
Old 10-18-2009, 11:20 PM
well after talking with you last time i measured i think the longest i can use is 27 to 28 inches. going to extend the one i have. other wise it will be around here forever. i have to hook behind the bags thats why brackets are so long.
  #12 (permalink)
Old 10-18-2009, 11:42 PM
F1CORY's Avatar
F1CORY F1CORY is offline
F1CORY is starting off with a positive reputation.
Whats up fellas..I would like to put in some thoughts..Big1 that panhard will have to be modified a good bit to work well "It's way to long and need's to have a slight bend or angle at one end" This will help in the push and pull of the rearend as it cycles..Have you thoght about cutting your upper bars and mounting them to the pumkin ears that you already have?? For me I think that would be less work then tryn to get that pan to work..Ohh yaeh gusset EVERYTHING lol GOOD LUCK..Roger I'm still workn on those pics I found some hard copys have to scan them in"somewhere"...I updated my gallery so far.
  #13 (permalink)
Old 10-21-2009, 09:32 PM
roger was looking at axle pic.you could put on front side of axle then use a brace to the pinion where the bracket is bolted on. these bags seem plenty strong for trailers the top bracket should fit on step. thought just hit me.
  #14 (permalink)
Old 11-01-2009, 12:55 AM
Quote:
I see what you mean about mounting on the front side, im working on this right now as we type/read.
__________________
Roger
1955 F100
  #15 (permalink)
Old 11-01-2009, 08:05 AM
cool
i think i,m not going to use pan hard. going to run an angled brace on 4bar. this would free up space. like to see pic's of install of your bags. have you tried to make any fancy braces with plasma cutter.
Tags
air , airbags , bagged , bags , f100 , ford , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
