Thanks all.
I replaced the coil with one that does not need a resistor and ran a fused wire from Battery through a 50amp swith to the coil. also replaced the cap, rotor, points and condenser..Why not right?
it runs good now, I figured it was the ingition switch until I started chasing wiring then I became unsure..
Painless has a bumper to bumper wire harness with fuse box and 6 new switches for $700 and change... is this the type you found and where?
__________________
1970 F100 2WD Short Bed 302/289 C4 Automatic.
