help! p0345, p0021, p0011 - Ford Truck Enthusiasts Forums
Old 10-18-2009, 10:08 AM
countryboy116's Avatar
countryboy116 countryboy116 is offline
countryboy116 has a very good reputation on FTE.countryboy116 has a very good reputation on FTE.countryboy116 has a very good reputation on FTE.
Hey ok the service engine light came on in my dads truck, its an 04 f150 with the 5.4, its got just over 40k miles on it, i had the codes pulled and i guess both cams are off timing and the camshaft position sensor is having a problem... what are the likely causes of this? THe truck is running fine so the timing cant be off too much, also can anyone tell me where i can the the cam position sensor on bank 2, is it possibly that maybe there is just a faulty connection somewhere between the ecm and the sensor? thanks in advance for your help
Old 10-18-2009, 08:26 PM
cmon, anyone know anything that can help me, i searched and seems that it could be a bad connection to the cam position sensor or just a faulty one ill check it but any other ideas?
Old 10-18-2009, 09:47 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
By far the most common cause I have seen is sludge build-up. The cam sensors are mounted in the timing cover just below the valve covers.
Old 11-01-2011, 06:44 PM
FordTruck54 FordTruck54 is offline
FordTruck54 is starting off with a positive reputation.
what is the best way to identify a cam sensor malfuntion in an 05 ford f150 5.4L it sounds like a deisel rather than a gas truck.
P2195, P0059, P1000, P0330, U0121, P0351... so many codes!! Please help!!! AGrayson84 1997-2006 Expedition & Navigator 4 11-01-2016 09:35 AM
Help needed Jonathan Day 2004 - 2008 F150 8 10-03-2016 04:06 PM
5.4L 3V with miss, rough idle and codes P0340, P0344, P0345, and P0349 jrbubachmech98 2004 - 2008 F150 53 06-11-2016 05:36 PM
06 F150 5.4 3V won't start Jiffy_1 2004 - 2008 F150 12 10-12-2014 02:23 PM
my truck wont wake up... tcfd1094 1994.5 - 1997 7.3L Power Stroke Diesel 5 07-24-2013 10:58 PM
Tags
04, 150, 2004, 2007, 250, 54, camshaft, code, f150, ford, intake, p0011, p0021, p0345, position, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
