MSD 6a, what to use for vibration mount?
Washers really do no good if the screw head touches the unit, and then screws into the truck. The best mounts have molded in screws that are trapped in the rubber, one will touch the unit and the other will bolt to the truck, with no mechanical connection except the rubber.
If you had some thick rubber squares, you could run a bolt upside down through the rubber and into the unit, and make sure the head doesn't stick out of the rubber, and then run a screw from the top down into the truck where the rubber square would stick out beyond the unit.
Khauler
13
01-31-2011 10:28 PM
OldFordRacer
Engine Swaps
09-04-2007 11:47 PM
GendoIkari69
15
04-28-2002 07:05 AM
