Heated seats - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Heated seats
Old 10-17-2009, 11:04 PM
Vinford's Avatar
Vinford Vinford is offline
Vinford has a good reputation on FTE.Vinford has a good reputation on FTE.
Heated seats
Well its that time of the year here again and my drivers seat doesnt heat up.
Does anyone know what makes them tick?
Old 10-17-2009, 11:09 PM
Excursion4X4's Avatar
Excursion4X4 Excursion4X4 is offline
Excursion4X4 has a good reputation on FTE.Excursion4X4 has a good reputation on FTE.
A broken wire in the seat, is why they usally stop working. You have to pull the seat cover off and replace the wire. You will notice scorch marks where the previous wire burnt up. I have done to another truck about 1 yr ago, now mine needs the same fix.
Old 10-17-2009, 11:59 PM
Vinford's Avatar
Quote:
Big job?
Have to remove seat?
Old 10-18-2009, 09:04 AM
WA.Ranger's Avatar
WA.Ranger WA.Ranger is offline
WA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to allWA.Ranger is a name known to all
Really easy fix. I just soldered in a new wire in the burnt section. I just had to pull the ouside of the drivers seat off to see the problem on mine. There was a good thread with pics, I'll see if I can't find it.
Old 10-18-2009, 11:16 AM
jeff7825's Avatar
jeff7825 jeff7825 is offline
jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.jeff7825 has a good reputation on FTE.
Subscribing. My driver's side doesn't work either and I was trying to look up the fix last night.
Old 10-18-2009, 11:40 AM
milleroutdoors's Avatar
milleroutdoors milleroutdoors is offline
milleroutdoors has a very good reputation on FTE.milleroutdoors has a very good reputation on FTE.milleroutdoors has a very good reputation on FTE.milleroutdoors has a very good reputation on FTE.
Quote:
Per Jeff's direction I was able to fix mine with a small piece of wire and a soldering iron. Maybe 1/2 hr of "engineering".
Old 10-18-2009, 10:40 PM
F250_'s Avatar
F250_ F250_ is offline
F250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputationF250_ has a superb reputation
What outstanding timing. The DS bun warmer in my '03 Excursion is not working either. My polar bear self doesn't need it, but my little bitty wife just doesn't have the same insulation I do, and I need to get it fixed for her. I was cruising the threads and getting ready to search the archives when I found this one. Thanks guys.
Old 10-18-2009, 10:44 PM
Izzy351's Avatar
Izzy351 Izzy351 is offline
Izzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud ofIzzy351 has much to be proud of
LOL... My cloth seats are plenty warm in the winter...
Old 10-18-2009, 11:18 PM
Quick444's Avatar
Quick444 Quick444 is offline
Quick444 has a great reputation on FTE.Quick444 has a great reputation on FTE.Quick444 has a great reputation on FTE.Quick444 has a great reputation on FTE.Quick444 has a great reputation on FTE.
How easy would it be to "add" heated seating to my seats?
Old 10-19-2009, 10:34 AM
F250_'s Avatar
Alex:
I've seen several aftermarket solutions and kits for doing just that. I didn't investigate thoroughly, but from what I could tell at a glance is that you'd have to simply remove the seat cover and then a basic wiring connection and switch install like any other electrical project.
Old 10-19-2009, 12:24 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
Quote:
Yeah what he said.....
Old 10-19-2009, 12:36 PM
Ponyboychris's Avatar
Ponyboychris Ponyboychris is offline
Hit it!
Ponyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud ofPonyboychris has much to be proud of
I've heard good things about this set-up:
Heated Seat Kit (dual)
Old 10-19-2009, 01:00 PM
kirkharrod's Avatar
kirkharrod kirkharrod is offline
kirkharrod has a good reputation on FTE.kirkharrod has a good reputation on FTE.
Wow, I don't need heated seats. With the 203* thermostat installed, it gets so warm in the cab that I have to crack the windows in the cab even with temperatures below freezing!
Old 10-19-2009, 03:39 PM
brandon_oma#692's Avatar
brandon_oma#692 brandon_oma#692 is offline
brandon_oma#692 is starting off with a positive reputation.
Anyone have a wiring diagram for a ford heated power seat? I have the power hooked up just unsure of the wires for the heater. 3 thicker wires????
Old 10-19-2009, 04:41 PM
jeff7825's Avatar
Quote:
Mine had white w/ red stripe, red w/ black stripe, and one other I can't recall off the top of my head.
Heated Rear Seats and BLIS MTDOG 2017 Super Duty 25 11-09-2016 10:52 PM
heated seat control module clifish 2011 & Newer Explorer 0 10-08-2016 05:03 PM
Help with heated seats daddgonemadd Excursion - King of SUVs 226 06-19-2016 07:14 PM
no heated seats gsxr1300 6.7L Power Stroke Diesel 33 01-05-2014 09:08 PM
heated seats are not working afonda 1999 - 2003 7.3L Power Stroke Diesel 4 04-06-2013 01:19 PM
Tags
06, 2001, 2007, covers, f150, f250, ford, heated, install, kits, problem, removing, seat, seats, timer, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
