Heated seats
Old 10-17-2009, 10:04 PM
Vinford's Avatar
Vinford
Vinford is offline
Heated seats
Well its that time of the year here again and my drivers seat doesnt heat up.
Does anyone know what makes them tick?
Old 10-17-2009, 10:09 PM
Excursion4X4's Avatar
Excursion4X4
Excursion4X4 is offline
A broken wire in the seat, is why they usally stop working. You have to pull the seat cover off and replace the wire. You will notice scorch marks where the previous wire burnt up. I have done to another truck about 1 yr ago, now mine needs the same fix.
Old 10-17-2009, 10:59 PM
Vinford's Avatar
Vinford
Vinford is offline
Big job?
Have to remove seat?
Old 10-18-2009, 08:04 AM
WA.Ranger's Avatar
WA.Ranger
WA.Ranger is offline
Really easy fix. I just soldered in a new wire in the burnt section. I just had to pull the ouside of the drivers seat off to see the problem on mine. There was a good thread with pics, I'll see if I can't find it.
Old 10-18-2009, 10:16 AM
jeff7825's Avatar
jeff7825
jeff7825 is offline
Subscribing. My driver's side doesn't work either and I was trying to look up the fix last night.
Old 10-18-2009, 10:40 AM
milleroutdoors's Avatar
milleroutdoors
milleroutdoors is offline
Per Jeff's direction I was able to fix mine with a small piece of wire and a soldering iron. Maybe 1/2 hr of "engineering".
Old 10-18-2009, 09:40 PM
F250_'s Avatar
F250_
F250_ is offline
What outstanding timing. The DS bun warmer in my '03 Excursion is not working either. My polar bear self doesn't need it, but my little bitty wife just doesn't have the same insulation I do, and I need to get it fixed for her. I was cruising the threads and getting ready to search the archives when I found this one. Thanks guys.
Old 10-18-2009, 09:44 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
LOL... My cloth seats are plenty warm in the winter...
Old 10-18-2009, 10:18 PM
Quick444's Avatar
Quick444
Quick444 is offline
How easy would it be to "add" heated seating to my seats?
Old 10-19-2009, 09:34 AM
F250_'s Avatar
F250_
F250_ is offline
Alex:
I've seen several aftermarket solutions and kits for doing just that. I didn't investigate thoroughly, but from what I could tell at a glance is that you'd have to simply remove the seat cover and then a basic wiring connection and switch install like any other electrical project.
Old 10-19-2009, 11:24 AM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is offline
Retired Mod
Yeah what he said.....
Old 10-19-2009, 11:36 AM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
I've heard good things about this set-up:
Heated Seat Kit (dual)
Old 10-19-2009, 12:00 PM
kirkharrod's Avatar
kirkharrod
kirkharrod is offline
Wow, I don't need heated seats. With the 203* thermostat installed, it gets so warm in the cab that I have to crack the windows in the cab even with temperatures below freezing!
Old 10-19-2009, 02:39 PM
brandon_oma#692's Avatar
brandon_oma#692
brandon_oma#692 is offline
Anyone have a wiring diagram for a ford heated power seat? I have the power hooked up just unsure of the wires for the heater. 3 thicker wires????
Old 10-19-2009, 03:41 PM
jeff7825's Avatar
jeff7825
jeff7825 is offline
Mine had white w/ red stripe, red w/ black stripe, and one other I can't recall off the top of my head.
Quick Reply: Heated seats
