Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-17-2009, 09:09 PM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of
My rear differential service - with pics
I serviced my rear differential today, and installed the Ford aluminum cover. I have 60k miles on the truck, and I tow frequently, submerge the axle occaisionally, and so I think it was due for service. I took a few photos and want to share them here. I used Guzzles guide found in the FTE tech folder, which is excellent and this is not intended to in any way take away from that, but there are a few tips I think I can add.
I bought the Ford aluminum cover, which is a great value at less than $50. Ford uses it on their '08 and above diesel SRW trucks, so if they think it is worth doing then so do I. It looks nice, and fits perfectly.
The cover does not come with bolts, and the original bolts are not long enough for the aluminum cover. You will need 5/16-18 x 1-1/4" long stainless steel bolts. I used hex head, you can use allen cap if you prefer. Quantity is 12, and add lock washers too. A good hardware store will have those for less than $10.
First tip, loosen your fill plug before you remove the cover. You don't want to get everything else done, and then find your plug is wallowed out. If it is it will be a problem either way, but I would want to know before I got started. The plug just uses a 3/8" square drive ratchet. Mine was in good shape. There is no drain plug on the Ford 10.25" diff. There is no fill plug in the aluminum cover.
My OEM steel cover was pretty rusty, but it was structurally sound and would have cleaned up and painted fine. Note there are two metal tabs with info stamped on them. One has your ratio code, and the other has the gear oil specification. Don't loose them.
I was pleased to find my gears in excellent condition, and there was no water or excess particles in my unit. This is nice to know, and the only way you know is to open it up and inspect. Note, I'm skipping the stuff that Guzzle does a great job of showing. Like removing the cover.
In the bottom of the differential casting are two wells, which will not drain without some help. It's important to clean these out well. Not only will metal particles settle there, but if there is any water intrusion it will settle there as well. Reach in and scoop it all out, followed with towels to get it all cleaned out.
Clean the sealing surface of all the old silicone sealant. Guzzle used emory cloth, but I prefer course Scotchbrite pads. I think it does a better job, and there is less chance of grains of sand getting where you don't want it. I used the red stainless steel pads, which are very abrasive. Next tip, chase the threads in the cast iron diff. They will be dirty and have old silicone. Since you are doing this on your own time, take a little extra time and clean the threads. You want at least 1" of good thread, but be careful not to cut the existing threads. Get it all spotless and clean all the oil off using solvent. Make sure the surface stays dry.
Next tip. A couple of studs in the threads will help align the cover without smearing the silicone around while you fumble with it. A couple of set screws would be best, but I didn't have any so I cut the heads off of a couple of long bolts. Select the two holes where the metal tabs will be replaced.
Here is the aluminum cover, and the gear lube I selected. This Mobil 1 full synthetic has the friction modifier in it already for the limited slip.
Here is the RTV silicone I chose to use.
Here is the silicone applied, and this brings up a point where I disagree with Guzzles writeup. I applied the silicone and immediately installed the cover on the differential. I don't know where the "let it skin over" thing came from, but I see it repeated often. I think that is a mistake. I want this cover glued in place and there is no point in letting the sealant partially cure before placement. I'm sure Ford doesn't do that. And I might add that the Permatex instructions don't say that either. So, suit yourself on that, but I've given my opinion. If it leaks, well we know who will be redoing it. I'm certain that it won't.
Here I have inserted all the bolts hand tight, except for the two studs. Next I just removed the studs with pliers, and inserted those bolts with the stamped metal tags under the heads.
Here it is all torqued down and finished except for filling with gear oil. Let the cover sit a couple of hours before you fill with oil to let the sealant get a good start on curing.
All that's left is to evaluate the Mobil 1 friction modifier. I drove around in a few circles, first one way, then the other, to try to distribute the new oil into the clutch packs. I don't know how much if anything that did. Time will tell, and if I get any clunking I can add some friction modifier later.
__________________
Folks call me Bill.
Please pass the GREEN nozzle.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto.Fleetwood Pioneer,23'x5,200#
  #2 (permalink)
Old 10-17-2009, 09:24 PM
juneau76's Avatar
juneau76 juneau76 is offline
2003 Ford F-250
My Garage
juneau76 is gaining momentum as a positive member of FTE.
Nice job, Bill. Great info and pics!
__________________
Brad
2003 F-250 Lariat Supercab 4x4 6.0L PSD, Fumoto, Updated HFCM Plug, DieselSite Bypass Coolant Filter, 22" Wiper Blades, more to come...
2008 Taurus X Limited AWD w/ a Fumoto (The Wife's Family Truckster)
Quote:
You haven't lived life until you've done 110mph in a Yugo
  #3 (permalink)
Old 10-17-2009, 09:31 PM
flamebuster flamebuster is offline
flamebuster is gaining momentum as a positive member of FTE.
Bill, great write up, lots of good details and pictures are excellent..
__________________
DOUG
2004 F-350 Super Duty Crew King Ranch . 6.0 psd...coolant, filter, slotted and drilled rotors,kitty ran away, air bags,leveling kit, progigy,piaa lights,
2003 EXP; All stock Wifes ride!!!
2006 2500HD gmc.All stock work trk.
  #4 (permalink)
Old 10-17-2009, 09:50 PM
wideglidewoody00 wideglidewoody00 is offline
wideglidewoody00 is starting off with a positive reputation.
Nice job on the write up. Does anyone know if that dif cover will fit a 04, 5.4 with a 3.73 rearend? If it will does anyone have the part number? I've wire wheeled and painted mine but the salt in Michigan will take its toll.
  #5 (permalink)
Old 10-17-2009, 10:46 PM
Ace!'s Avatar
Ace! Ace! is offline
Ace! is gaining momentum as a positive member of FTE. Ace! is gaining momentum as a positive member of FTE.
I never let it "skin over" either and have done a diff a LOT of times. I think I understand why they say it, but I don't think it works any better. Some diffs have a gasket and you could consider that dry, so I think that's sort of where it comes from. But, when making your own gasket I think it's best to follow the "Permatex" directions. It's worked for me a dozen times or more with no hint of a leak.
__________________
2005 F250 V10, CC, SB, 4x4, 4.30 axle ratio
1994 Exploder XLT, 4x4, auto trans and Pioneer cd player
"Deserve's got nothing to do with it"
  #6 (permalink)
Old 10-17-2009, 10:48 PM
61 uni's Avatar
61 uni 61 uni is offline
61 uni is gaining momentum as a positive member of FTE.
Quote:
I think all of the 99+ f250 and SRW f350's use the same rear end.
__________________
Brandon
2002 Crew Cab f350 DRW 7.3. Stancor GPR 6637 Filter Born 3/11/02
1978 f350 400 4speed
  #7 (permalink)
Old 10-17-2009, 11:02 PM
slowmans slowmans is offline
slowmans is starting off with a positive reputation.
Quote:
yup
__________________
2006 F350 LARIAT 6.0 SUPERCAB 4X4 FX4
4"MBRP T-409 TURBO BACK COOL DUALS
EDELBROCK PERFORMER IAS SHOCKS
ACCUFAB POLISHED INTAKE ELBOW
KITTY IS AT THE VET!!!
305/65/18 BFG ALL-TERRAINS
DRINKING B-5 REGULARLY
08' REAR DIFF. COVER
  #8 (permalink)
Old 10-17-2009, 11:57 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
2004 Ford F-250
1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE. 1975StroppeBaja has a good reputation on FTE.
Great write up, tips, and pics
Those are some good lookin' shocks too!
I'll try & remember to rep ya after spreadin it around some more.
  #9 (permalink)
Old 10-17-2009, 11:58 PM
bpounds's Avatar
2 bit Californian
All the single rear wheel Superduties use the same differential, up to at least 2010. You can find the part number for the aluminum cover here:
www.partsguyed.com
They are an FTE sponsor too.
Part number is 8C3Z4033A
__________________
Folks call me Bill.
  #10 (permalink)
Old 10-18-2009, 12:23 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
Big J
2005 Ford F-250
powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of
Quote:
Got him for you Jason.
Excellent job with the write-up and pics Bill! Thanks for posting it.
Any mods that see this.....I'm thinking maybe a sticky in the tech folder would be a great idea.
__________________
John
2005 F-250 SD Lariat CC 4x4 6.0 TS Auto.
2007 GMC Yukon Denali
  #11 (permalink)
Old 10-18-2009, 12:41 AM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
Those teeth couldn't mesh any better. Nice cover but I wish you would have shown how you filled it, I don't have a suction gun. I think Guzzle "squished too much out" and came up with the " let it skin over" theory but I don't use it either and I'm sure Ford is not going to look out the window while it "skins over" either. .....nice pics.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #12 (permalink)
Old 10-18-2009, 07:19 AM
senix's Avatar
senix senix is offline
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
nice write up, that cover does wonders for reducing the temps. I too agree, you don't need to let the sealant "skin over" Other than that there is nothing I would have done differently.
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #13 (permalink)
Old 10-18-2009, 10:12 AM
bpounds's Avatar
2 bit Californian
Quote:
I should have, but it was a couple hours later and I had put the camera away. But it wasn't any problem.
The gear oil bottles have a nozzle built into them, and you can just stick it in the hole and squeeze out all but about 1/4 of each bottle. Then I used a piece of 1/2" nylon polyflow tubing about a foot long, stuck it on the bottle nozzle, the other end in the hole, and squeezed the last little bit. That overfills it a little bit, so you just wait for it to drain back until level.
I don't think I needed the tubing though. I could have emptied the last bit of all the bottles into one, and just stuck the nozzle in the hole.
Either way, there is lots of room under there and it is not a problem.
Thanks for all the kind comments.
__________________
Folks call me Bill.
  #14 (permalink)
Old 10-18-2009, 02:01 PM
Thank you for that part number.
  #15 (permalink)
Old 10-18-2009, 06:09 PM
Furian's Avatar
Furian Furian is online now
You Keep What You Kill
Furian is gaining momentum as a positive member of FTE. Furian is gaining momentum as a positive member of FTE.
Excellent write-up w/ pics... REP's given!
__________________
Andrew
2005 F-350 4X4, Regular Cab Long Bed, XL Package, 5.4L 3V Engine, TorqShift®, 4.10 Limited Slip, K&N CAI Kit, SCT Livewire w/ Custom Tunes from 5 Star Tuning
Tags
1025 , 60k , cap , cast , determine , differential , end , f250 , f350 , ford , iron , oil , plug , rear , service , truck , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
