Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
- How to Replace Rear Differential
Step by step instructions for do-it-yourself repairs
My rear differential service - with pics
#106
I check mine every October to get ready for winter, and the last 2 years my rear diff.was contaminated with water.(brown runny oil) The first time I found contamination I thought it was from backing to far in the water to launch the boat, but last year I never pulled the boat and the only water I drove in was standing water on I-5 in Portland Oregon during a torrential down pour...I am guessing it's getting in thru the breather which was mounted to the left rear spring above the axle. So I moved it to a cross member in the center of the truck above the axle.
Point is even if it isn't time to change the oil, check it often. I plan to check mine every couple of months till I am sure I got this water issue fixed..
#109
I'm not sure on the axles but the np 271 transfer case takes just under 2 quarts of Mercon V. I changed mine when I rebuilt my transmission last week at 121,xxx and it was black. I used B&M Trick Shift to refill.
#110
Really good post with the added pictures. I found that Fel-Pro makes a gasket for the rear diff also - PN RDS55394. I priced it at around $7.00. It could be used in place of the silicone constructed gasket with no down time waiting for silicone to set up. Also the piece of mind in not using too little or too much silicone getting the job done.
#112
Mineral spirits for cleaning. And I chose the RTV that is "Maximum Oil Resistant". Red is for high heat, which you don't need here. Not sure about the ultra gray. Probably fine.
#114
#115
wpnaes
12-28-2020 10:56 PM
coolfeet
04-05-2016 09:58 AM
