Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
- How to Replace Rear Differential
Step by step instructions for do-it-yourself repairs
My rear differential service - with pics
#76
#77
Mag-Hytec seems to be the gold standard, and they price them that way too. It's not worth it to me, with just standard HP output. What I would consider is just buying a new OEM steel front cover and having it powder coated (or chromed) in advance of starting the service. I'm sure there are other brands out there too.
#78
#79
Ford has an aluminum finned cover for the rear, for the 2008-up diesels that fit the eariler rear ends. We have a Ford dealer parts guy as a sponsor here, Ed. Pretty cheap.
I took my old rusty rear cover on my '01, sanded, primed with zinc chromate primer, painted with Volvo Marine silver metallic, and it still looks great after 3 or 4 years.
#81
Front diff (Dana 60) calls for Motorcraft SAE 80W-90 Premium Rear Axle Lubricant @ 5.8 pints
Rear diff (10.5) calls for Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant @ 6.9 pints
#84
I remember reading (here on FTE) that when the Sterlings first came out, they used conventional 75w90 or so, but they had a lot of failures. Using 75w140 synthetic made the problem go away. Not sure if that's true or not. I think the issue was the front pinion bearing overheating.
Which doesn't surprise me. Lots of 8.8's and other Ford stuff I've opened up has some non-Timken brand (NTN?) front pinion bearing in it. They ALL have signs of overheating. Every other bearing in the unit is Timken and looks perfect, and I've even seen some units with Timken front pinion bearings that looked perfect. Replacing that front pinion bearing with a Timken, and after taking them back apart years later, never seen any problems.
#87
Tip: Drain The Axle Tubes/Sleeves
A tip for the "**** perfectionists,,,"
**** Perfectionist or not,,, it's a good idea to drain the axle tubes/sleeves when servicing your axles to avoid the few ounces of old gear oil that can be sitting in there mixing in with your fresh "exspensive!" synthetic or not gear oil and or friction modifier.
While draining the gear oil jack up each side of the axles (one side at a time) to drain the fluid from the tubes/sleeves. Depending on the angle your truck is resting on there can be a few onces of gear oil in the tubes/sleeves.
When servicing my vehicles I try to park with a slight angle to one side or the other to allow one side of the tubes/sleeves to drain with the initial draining of the oil.
When that portion of the draining process is done I jack up the lower side to allow the trapped oil in that side to drain. I always allow at least a few hours or over night of drain time to make sure I get as much of the old oil out as possible.
Service safely,,, use good wheel blocks and common sense when taking on what should be a painless and simple project.
Rick...
Rick...
#88
#89
Can we GET anymore ****?
I didn't realize there was anywhere else the gear oil would pool. I thought I was getting pretty much all the gear oil possible by tilting the axle a good foot or so for a few hours on each side.
Rick...
Rick...
