There are no cracks, that is a view of the 1 halves of the spider housing and the end of the spider gear pin in that hole with a machining mark at the end of it.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
Great write up. In the 1st picture with the cover off, inside the round cutout, does that look like a crack?
No crack, fresh out.
__________________
I hope this is not a dump question to all. When you service your rear diff I notice you remove the cover, drain, inspect and add new fluids. Should you do the same for the front diff? Does ford or any aftermarket make a aluminum covers for the front diff? Is it necessary to change the front cover to aluminum?
Hey Mike, the front diff gets serviced the same as in the rear...idk if Ford makes a aluminum cover for the front,and no its not nessary to to have aluminum covers at all, but these covers help distrubute heat aswell as add strenght to the axle hosing...hope this helps?...
__________________
BIG JOE
2000 F250 PSD Extndcb SB 2wd bone stock (not for long)
1986 F-250 4x4 RC 2sd owner 460 C6 some mods
For the front, I just used a hand pump, emptied it, and refilled. I didn't feel like messing with the cover, with that tie-rod right in the way
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased! I've been wrong before, I'll be wrong again. Just wait and see.
For those running the Mobil 1 that says it already had the LS additive in it, did yall have to add some Ford friction modifier to it? I know I did. Just wondering.
I've got about 700 miles on it now, and I have not had any grabbing. That's enough miles to comfortably say I won't have to add any FM.
What I don't know is how well the LS is working. Not going to worry about it.
__________________
Folks call me Bill.
Please pass the GREEN nozzle.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto.Fleetwood Pioneer,23'x5,200#
I changed my rear gear oil a couple of months/5000 miles ago, using the same Mobil 1 75W-140.
I have had no chattering on turns at all, and I did not add any of Ford's friction modifier additive. The Mobil seems "good-to-go".
Pop
__________________ -Marv- one of the Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks,
and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, coolant filter, 6637 & cover, bypass oil, HPX. Email SpringerPop
Too much friction modifier is'nt good, as it makes the clutches slip more.
Also Mike there is no such thing as a dumb question...
+1 on that!
__________________
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
