Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-18-2009, 10:28 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Added to the tech folder, right after guzzle's write up.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #17 (permalink)
Old 10-18-2009, 11:21 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
Big J
2005 Ford F-250
powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of powerstroke72 has much to be proud of
Quote:
Thanks Art!
__________________
John
2005 F-250 SD Lariat CC 4x4 6.0 TS Auto.
2007 GMC Yukon Denali
  #18 (permalink)
Old 10-19-2009, 06:53 PM
Rugby3's Avatar
Rugby3 Rugby3 is online now
Rugby3 is starting off with a positive reputation.
Thanks for the write up and information on the new cover! I wanted to add a new cover but not at the price some of the aftermarket ones go for even with the extra capacity. I did mine about 3 months ago and didn't let it skim either. It hasn't leaked yet.
__________________
01 F-250 XLT CC LB V-10 4x4
True Blue/Silver Metallic
Got HossPower?
  #19 (permalink)
Old 10-19-2009, 07:01 PM
Krewat's Avatar
I've found over the past 20 years of using RTV that letting it skin usually makes it last longer. I think the idea is that if you tighten the cover enough, without it skinning over, you can actually push out all the RTV between the cover and the housing. Then, it will leak.
If you do not tighten it enough for that to happen, it doesn't leak
__________________
  #20 (permalink)
Old 10-19-2009, 09:49 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
That was Guzzles' theory and it does make sense to me the more I think about it because they can't make it thick enough to be used directly from the container and anything that thin will be squished to a thin film with that much pressure.
__________________
Brent Bradley Scenic photographer and former mechanic with car and motorcycle drag racing background. Also, avid snowmobiler.......retired. The Ex; custom mudflaps
  #21 (permalink)
Old 10-20-2009, 10:29 AM
bpounds's Avatar
bpounds bpounds is online now
2 bit Californian
bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of bpounds has much to be proud of
Quote:
The Permatex instructions address that issue. Basically, assemble immediately while RTV is wet, lightly tighten to squeeze out evently, wait 2 hours and re-torque. I did not do it exactly like that.
Here are the instructions:
http://www.permatex.com/documents/td...tive/82180.pdf
I think that is far different than letting the open beads skin over, which is how I interpret Guzzle's writing. But I could be misinterpreting.
Here is the main Permatex page for the product I used:
http://www.permatex.com/products/Aut...sket_Maker.htm
__________________
Folks call me Bill.
Please pass the GREEN nozzle.
2006 F250 XLT SCLB FX4 4x4 6.0L Auto,Magnaflow Turbo Back,RhinoLiner,Retrax Cover,Cab Lights Retro-fit,Overhead Console Retro-fit,Bilsteins,Harpooned,C-Betrs,Fumoto.Fleetwood Pioneer,23'x5,200#
  #22 (permalink)
Old 10-20-2009, 12:42 PM
EXv10's Avatar
That makes even more sense to me.
__________________
  #23 (permalink)
Old 10-20-2009, 12:58 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
2008 Ford F-250
TexasRebel is gaining momentum as a positive member of FTE. TexasRebel is gaining momentum as a positive member of FTE.
just curious, but is there not a gasket for the 10.5"?
__________________
2008 F-250 5.4L Reg. 4x2 6-spd 4.10
DIY Factory Upgrades: Installed TowCommand Brake controller, Upgraded to 4 spkr. Single CD/AM/FM w/AUX from 2 spkr. AM/FM, cab clearance lights, B&W "Turnoverball"
1977 C-10 Silverado
2002 1500 Silverado (sold )
  #24 (permalink)
Old 10-20-2009, 01:04 PM
senix's Avatar
senix senix is online now
senix is gaining momentum as a positive member of FTE. senix is gaining momentum as a positive member of FTE.
no gasket, just the permatex
__________________
2008 F250 PSD Crew Cab 4x4, X-liner,
Cooper Discovery STT LT275/70R18's
Skyjacker dual steer stabilizer
Banks Ram Air & 6-Gun, Upfitter switches
Ravelco Alarm System, Frontier Extreme FT. Bumper
  #25 (permalink)
Old 10-20-2009, 01:12 PM
EXv10's Avatar
I guess the days of the gaskets went away with the advent of the hi-tech sealers............to a point.
__________________
  #26 (permalink)
Old 10-20-2009, 01:23 PM
TexasRebel's Avatar
2008 Ford F-250
Also curious, did you take the time to check the lash in the gears while it was open?
__________________
1977 C-10 Silverado
  #27 (permalink)
Old 10-20-2009, 01:28 PM
bpounds's Avatar
2 bit Californian
Quote:
No. I had no reason to suspect an issue like that.
__________________
Folks call me Bill.
  #28 (permalink)
Old 10-20-2009, 02:24 PM
EXv10's Avatar
Checking and changing the lash can be detrimental. The lash can vary with the gearset due to the original cutting of the teeth. What is more important is the contact area which can be checked with red lead, prussian blue, etc. Basically if it doesn't whine, don't touch it.
__________________
  #29 (permalink)
Old 10-20-2009, 02:34 PM
senix's Avatar
Now that is the best advice! If it an't broke don't fix it. I'd rep ya but I gotta spread the love first.
__________________
  #30 (permalink)
Old 10-20-2009, 02:46 PM
Vijay's Avatar
Vijay Vijay is offline
2000 Ford F-350
Vijay is starting off with a positive reputation.
I just replaced mine as well. I did both front and rear....
__________________
F 350, 2000 Lariat LE, 7.3 PSD(Forged metal rods!!!), Dually, LB, Alpine AM/FM/CD/DVD/NAV, SUPERCHIP, 5 inch exhaust.
Tags
1025 , 60k , cap , cast , determine , differential , end , f250 , f350 , ford , iron , oil , plug , rear , service , truck , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
