Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 3.0L V6
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-17-2009, 06:33 PM
juan0214 juan0214 is offline
juan0214 is starting off with a positive reputation.
1998 Windstar 3.0 runs rough
Bought van a year ago. Changed all the plugs a real pain, 5k later #3 blows out reinstalled it change wires too. #1 not firing checked all wires R&R and rerouted them. Four weeks ago she starts running rough. Replace coilpack ran the same. Sent van to regular mechanic. They changed the coilpack, installed two (used) ECM, still ran the same. Changethe back plugs #1-3, check for spark, injectors, fuel presure, engine compression, electrical wiring, pulled all the O2 sensors and checked the wiring to them, everything was fine. Four hundred thirty-five dollars and a week later he gave up and it still ran the same. Van struggles to get to 30 MPH (tranny or engine)? It's still running rough, after it gets to 30 MPH she runs good, until you get to a hill then she struggles at 20 MPH. I can here a backfire from the engine (sound like from the left side of van). Blew the oil pan gasket out two weeks ago (pressure?). Thats fixed now our mechanic asked $350 to change it (got it done for $100 + parts w/oil and filter change). And this mechanic put in a coilpack N/C and it's still running the same. Seems like when it's cold it runs fine after it's warmed it runs rough. Changed PCM again today stillo runs the same, but warning lights did shut off for a bit.
Any ideas????????????? Greatful for any help.
  #2 (permalink)
Old 10-19-2009, 08:26 AM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
sound like some needs to do a compression test on the engine.these engines are know for burning valves.just a idea seeings how you didnt state that it was done.
__________________
ASE MASTER TECH FORD SENIOR MASTER TECH
  #3 (permalink)
Old 10-19-2009, 09:41 PM
wtroger wtroger is offline
wtroger is starting off with a positive reputation.
Check back pressure on exhaust this sound like a plugged cat conveter
Tags
1998 , 30 , 96 , 98 , backfires , backfiring , faq , ford , lights , rough , runs , van , warning , windstar
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
