Broken Lumbar Support - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 10-17-2009, 02:41 PM
h2guy h2guy is offline
h2guy is gaining momentum as a positive member of FTE.
Anyone have a diagram/drawing/pic of how the cable in the seat back of an '01 Lariat Capt's Chair seat lumbar support mechanism is rigged??
Mine has broken at the cable's end but I think I can fix it but don't know thru which holes or pieces of the framework the cable runs through & over to tension up the support itself.
"Preciate it!!
Old 10-17-2009, 03:04 PM
agg_bagg agg_bagg is offline
agg_bagg is gaining momentum as a positive member of FTE.
subscribing. interested on how they work.
Old 10-17-2009, 03:55 PM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
Mine broke right after I bought the truck.
I had tightened it down too hard and it pulled the cable out of the upper whatchamacallit that adjusts the lumbar.
I didn't take any pictures, but basically you have to remove the seat back from the bottom half. There are bolts that secure the seat back to the bottom half underneath the side trim on the bottom.
Once that is done, lay the seat back on the bottom half and look along the bottom of the seat back's upholstery.
You will see the seam there, separate the seam and lift the upholstory up off the seat.
What I found was the cable was still good, but the female part of where it goes into was pulled through because I cranked it down too hard.
I re-inserted the cable and then fashioned something around the base of the end of the cable so that it was much larger than it was before.
The hardest part was getting the bottom seam back together because I had to overcome the tension of the fabric and get the seam to zip back together.
Old 10-17-2009, 08:51 PM
Thanks Dan. I've gotten the seat back off okay, but I don't understand the routing of the cable. Thats what I really need to "see".
Old 10-17-2009, 08:59 PM
zx250's Avatar
zx250 zx250 is offline
Of the next Riffraff East
zx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant futurezx250 has a brilliant future
I replaced mine a few years ago, but don't remember being any problem routing the cable. I had to replace the lumbar support itself. Not hard once you get to it.
Old 10-17-2009, 11:09 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
Does the passenger side have lumbar? Could take that one off and look. It's what I had to do on mine.
Old 10-18-2009, 08:56 PM
As Roberto DiVecinzo said when he lost the Masters by signing an incorrect scorecard:::::
I AM A STUPID!!
As pointed out, the passenger seat has what I'm looking for installed in it.
Duhhhhhh.
Old 10-18-2009, 09:11 PM
jeffdoerr jeffdoerr is offline
jeffdoerr is starting off with a positive reputation.
I have some extra lumbar parts if you need. These are easy, the worst part is removing the seat from the truck. Pull the armrest cover back, remove the bolt. Unhook the back seat cover, at the bottom.. . Roll up the back seat cover about half way, just grab and pull, let it roll inside out. Pull the foam insert away from the frame and all the stuff is there. Nothing to it. Just a simple plastic part that will eventually break. Easy to change. I have done 4 of these in the last few months. Its also a good time to add seat heaters at this point.....
Old 11-24-2011, 03:33 PM
jetflyr jetflyr is offline
jetflyr is starting off with a positive reputation.
In reference to your lumbar support response from a few years ago; did you replace the actual bag that inflates? If so, where did you get it?
Thanks,
TOM
Old 11-25-2011, 11:16 AM
Quote:
Thanks,
TOM
Mine wasn't a bag that inflates, it was a square plastic pad that would bend like a bow when you tightened the cable.
That is what provided the lift on mine.
Old 11-25-2011, 05:05 PM
Bonanza35 Bonanza35 is offline
Bonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to beholdBonanza35 is a splendid one to behold
Any body have to replace the handle. Mine broke off a couple of years ago. I guess sliding out of the truck I use to catch it and broke the round handle. Thanks ahead of time,
Chet
Lumbar support bags? RÖENTGEEP 1994.5 - 1997 7.3L Power Stroke Diesel 10 07-20-2016 09:29 PM
Power seat lumbar support repairs? Warracresok Explorer, Sport Trac, Mountaineer & Aviator 6 03-09-2015 10:05 AM
Broken Drivers Seat Lumbar Support 03-6L-X Excursion - King of SUVs 2 05-10-2010 04:55 PM
2007 Explorer manual lumbar question rpxr400 Explorer, Sport Trac, Mountaineer & Aviator 1 08-11-2009 09:06 PM
Broken lumbar support pgw85706 Ranger & B-Series 1 09-30-2008 03:52 PM
Tags
2003, 2007, broken, cable, diagram, f150, f250, ford, fords, lumbar, part, parts, seat, support, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
