Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Ranger & B-Series All Ford Ranger and Mazda B-Series modelsSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-17-2009, 12:41 PM
mitch_c mitch_c is offline
mitch_c is starting off with a positive reputation.
Exclamation 4cyl '02 Ranger Excess Oil Loss- no smoke
We have a 2003 Ford Ranger, 4cylinder, automatic with 83,000 miles. It is consuming 1 qt of oil about every 100 miles of road driving... We find no leaks, can't see any smoking, compression is within 10 pounds of each other per cylinder and at 175 PSI... Can't figure out where the oil is going...
Only see 1 cylinder with any electrode ware on the spark plugs.... Engine runs smooth....
We are baffled... Any suggestions? Any similar experiences?
HELP!!!
  #2 (permalink)
Old 10-17-2009, 04:14 PM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
No leaks, unbelievable.
Is this leak check done with pressure in the oil system? Or with the driveway check?
  #3 (permalink)
Old 10-18-2009, 01:39 AM
Leak check not done... no spots in the driveway and engine is dry on the bottom side... It's baffling us....
  #4 (permalink)
Old 10-18-2009, 03:03 AM
tomw tomw is offline
tomw is gaining momentum as a positive member of FTE.
Is it overfilled perhaps? If the dipstick is wrong, you can be at "full" and the engine will eat what it wants before stopping if overfull.
Is the PCV system working? Plugged can cause over pressure in the crankcase and feed the valve guides.
Is the oil of the specified viscosity? Too lignt an oil may consume more.
Is it driven regularly to boil off any condensation? Condensation will fall to the bottom of the crankcase, and give you a false oil level reading which will drop quickly the first time you take any sort of a trip. Been there, done that.
tom
__________________
It's not how hard you work, it's how much you get done. Simplificate and add lightness
  #5 (permalink)
Old 10-18-2009, 06:52 AM
03 Maz B23 03 Maz B23 is offline
03 Maz B23 is starting off with a positive reputation.
The valve cover on the Duratech 2.3 has two valve cover gaskets (inner and outer). The inner one on mine leaks and allows oil to get on spark plug threads and probably in combustion chamber. It's a pain to replace gasket as the entire intake and surrounding hardware has to be removed to get to it. That might account for some of your oil loss.
  #6 (permalink)
Old 10-20-2009, 12:49 PM
coolcamo coolcamo is offline
coolcamo is starting off with a positive reputation.
when i changed my spark plugs on my ranger. One of the electrolites was burned and there was nothing on the spark plug.
  #7 (permalink)
Old 10-20-2009, 12:59 PM
Exclamation
Folks... I posted this problem for CoolCamo before he had and ID on the site.. Please post any info that might be of assistance to him and I'll let him supply the responses..
  #8 (permalink)
Old 10-21-2009, 09:41 AM
thanks mitch_c
  #9 (permalink)
Old 10-28-2009, 07:49 AM
dorman68's Avatar
dorman68 dorman68 is offline
dorman68 is starting off with a positive reputation.
Check the pcv hoses, pcv valve and oil separator on side of block. My buddy with a 2.3L 05 Escape had a similar issue and it ended up being a collapsed pcv hose.
__________________
Tin man in the rain - I'm afraid I'm a bit rusty yet - 1993 Ford Ranger 2.3L - 2WD, 5-Speed
Tags
2.3l , 4 cylinder , 98 , cyl , cylinder , ford , leaks , loss , losses , oil , oil consumption , oil usage , plugs , ranger , smoke , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
