Hate to ask for help. . .but no spark
Pickup: 1987 F-150 with 351W. I posted this here rather than the 87-9x subforum because the 351 was left carburated while the other 87 models were EFI.
Backstory: drove this truck through highschool/college, then parked it in the barn for about 6 years.
Bad news: rats built a *huge* nest in the engine bay, and chewed through some wires.
Good news: radiator still full of bright green fluid, carb/intake was covered up so nothing could get down in the engine.
The problem: 12v to both sides of the coil, but not getting any spark when cranking.
Replaced plugs/wires/cap/rotor/ignition module. You can see from the pics that the wire from the harness to the oil pressure sending unit is shot, but I wouldn't think that would cause a problem with *spark*.
New ignition module plugged into the wiring harness. Not sure what the 2nd pigtail is for. . .
Coil, and associated wiring.
No, sir. With the key in the start position, I have 12v on both the + and - coil connections, but no spark out of the coil.
So you've replace pretty much everything but the coil. Got 12v going into the coil but nothing coming out of the coil... I think I'd try a new coil. Not gonna hurt, if ya get a new one and throw it on and it still doesn't work it's easy enough to pull off and take back.
But I'll go look closer. . .this OU/Texas game is making me sick to my stomach. Need a good excuse to go outside for awhile.
To Make the truck run just use a jumper wire from the battery + to the red wire on the IGN module. This is what powers the IGN module and it will not work if you dont give it power.
You really dont need to use the white wire in the 2 wire plug if you dont want to mess with it. It shoud be easy to follow the wires back from where the rat chewed into them. The red wire should have 12 volt with the key in ON and START.... the white wire will have power in START key position only.
Jim
Jim
on
Originally Posted by ctubutis
Are you absolutely positive about that? That doesn't sound right to me (but I don't know
the specifics for certain).
This is a complicated issue. Both of you are 100% correct.
This is because it depends on if you have a aftermarket or replacement module or the original factory module.
Factory Modules are color coded:
Red/Lt. Blue: Start.
White/Lt. Blue: Run.
Some aftermarket and some motorcraft replacement modules have these wire colors inverted at the connector.
Red for white, and White for Red.
Evidence of this can be seen in this picture.
This is why the colors invert at the connector on replacement modules. The truck harness wiring remained the same and matches the factory module, while the replacement module harness swapped colors. Why also some aftermarket diagrams are contrary (like the one posted above) to the factory diagrams.
This is why, both of you are correct. Also makes it confusing as heck.
Don't uncross the wires (if they cross like in the pic) otherwise it will be wired wrong. Also if you have an original module, the wire colors will match all the way from the truck harness to the module. (Don't make them Cross).
Hope this helps.
Hope this helps.
