1976 ford 1ton 2 wheel vs 1989 ford 3/4 ton 4 wheel
my question is i have a tow truck bed i am wanting to put on a truck which one would you guys recommend i have a 1976 ford 1 ton 4 speed 390 v8 2 wheel drive or a 1989 ford 3/4 ton automatic 7.3 diesel 4 wheel drive both trucks run good just trying to decide which one thanks
is either one dually,, which trans is the automatic, what are the normal conditions that you plan to use it in. all factors to consider, but personally i live in pennsylvania and all the tow trucks around here are 2wd even with the snow they do fine, mostly due to the fact of being duallies, but the standard would be a better bet plus with the heavier suspension would be better suited to handle towing, the 4x4 would be more of a plow truck (again if you live in a snowy area)
71_ford
03-27-2016 07:09 AM
big bern
17
02-23-2015 06:15 PM
Truck Guy99
57
03-04-2014 10:18 AM
