Just got a '78 Crew Cab 4x4
Hey Guys,
I found a 78 crew cab and went for it. I put pics in my gallery. It's not the prettiest thing you ever saw and has been neglected some but I didnt' get it to make a show truck out of it. I got it to take my wife and 3 kids 4x4 in the mud and on the trails and camping. I just love to see an old crew cab throwing mud!
I plan to get it mechanically 100% and lift it some and then go play! This is my first venture into 4x4 so I'll probably be on here with lots of questions. I put pics in my gallery. Woohoo!
Plan to go with standard bed. I just took the bed off today and I'm going to put it up for sale - figured it would be easier to fix the broken spring hangar with it off anyway.
Thanks fordtrucknut! I already learned that a front dana 60 would have king pins but how can you tell that the rear is a 60? It does have the number 60 stamped on the rear end but I figured that was just too easy.
Thanks...
Thanks...
All 1953/82 F250's have a Dana 60 rear axle. Most 1983/85 F250's have a Dana 60 rear axle.
If you post the AXLE code found on the Warranty Plate, once decoded, the ratio and whether it has Limited Slip...or not...will be known.
The Warranty Plate is located on the left door face below the latch.
The spring hanger may still be available from Ford.
Which spring hanger is it? At the front of the rear spring, or at the rear of the rear spring?
Axle code is 24J?
Trans code is G?
AAD - have no idea what that is...
F265? No idea either - thanks.
