Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Colorado Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Colorado Chapter Join Chapter, Leader: RIKIL
  #1 (permalink)
Old 07-11-2002, 06:05 PM
MileHighFordFan MileHighFordFan is offline
Garage is empty, add now
MileHighFordFan is starting off with a positive reputation.
Recommend Diagnosis Shop in Denver area
  #2 (permalink)
Old 12-27-2002, 01:43 PM
V8EXPLR V8EXPLR is offline
V8EXPLR is gaining momentum as a positive member of FTE.
I'm looking for a good shop in the Denver Metro area for diagnosis of a problem? I have taken the Explorer to Lakewood Fordland, Barbee's Freeway Ford, L&R Automotive (Ford specialists in Arvada) and also AutoFX (Arvada), which not one of these shops were able to diagnose the problem I am having.
1999 Explorer 5.0 AWD w/AT @ 59K miles
I'll try to explain the problem as quick as possible:
Started up the X in July and noticed the engine was running rough, and I could feel a pulse through the brake pedal when applied. About 1 block later the CEL came on, and was diagnosed to be a bad #4 plug. Had all 8 plugs & wires changed out with Motorcraft plugs & wires, and CEL has not come back on. Since that point I've had an intermittent problem I'd describe as: lack of power, loss of power, and rough idle. This problem is most noticable when: driving on any form of incline, between 30-40mph (OD off) or between 40-50mph (OD on), trying to pick up interstate/highway speed, when reaccelerating from slowing down or coasting. I've replaced the: EGR, TPS, IAC, PCV, all 4 O2's, Fuel Filter, Fuel Pressure Regulator, plugs and wires which nothing has helped. The idle runs at about 1200 RPMs when started cold, until it warms up. Which I think is high even when cold, since it never idled this high before the problem. The X doesn't have the push you back in your seat power upon acceleration anymore, this would be the loss of power. Lack of power is when the problem is at it's worst during the above scenerio's. When the speedometer is 30-40mph(od off) or 40-50 (OD on), the RPMs are right around 1500. When the X is around this point, the X stubles every once in a while and the engine sounds like it's bogging down. Also when accelerating sometimes, the RPMs will drop 300-400 instead of climbing. It doesn't drop because it shifts, the RPM's just drop and I feel the power loss through the gas pedal. The Engine tone doesn't sound right, and the exhaust tone is deeper now.
One of the above shops stated the problem was the IAC & fuel pressure regulator. Neither of these items worked. The other three shops stated the X was running at spec. and they couldn't find anything abnormal or off. Please let me know of any thoughts regarding the problem, or of a good shop to check the X out. I'm getting frustrated since I've paid $400 in diagnosis fees and just over $500 in parts, and the X still runs like doo. Thanks for the help in advance everyone!
__________________
Justin
2006 Ford F-150 SuperCrew XLT Chrome Edition
5.4L Flex-Fuel, 3.73LS, 18" Stock Rims, 18" BFG Rugged Trail T/A's, Trailer Tow Pkg
Sun/Moonroof, Fog Lamps, Ford Bedliner
Lund Headlight & Taillight Covers, Lund VentVisors
  #3 (permalink)
Old 12-27-2002, 11:26 PM
Paarrothead's Avatar
Paarrothead Paarrothead is offline
Paarrothead is starting off with a positive reputation.
Check your battery voltage and charging system with a digital voltmeter. A few minutes after starting on a cold day you should read at least 14 volts at the battery terminals and no less than 13.5 to 13.8 after it's warmed up and running. Check it several times. Low voltage can cause a lot of unexplained problems.
Has anyone pulled an oxy sensor, stuck a gauge in the hole to read the back pressure of your exhaust system? Plugged catalytic or muffler, perhaps?
Local Auto Zone stores offer a free reading of any codes that might be set in your vehicle.
That's about all I can think of, offhand.
__________________
2002 F-250 S/Cab PSD 4x4.
SCMT 110 HP, 10K mod, BB turbo, AFE Magnum, Magnaflow 4" turbo back, MAP regulator, Bridgestone Revo 285s.
  #4 (permalink)
Old 12-28-2002, 10:53 AM
bubbaf250's Avatar
bubbaf250 bubbaf250 is offline
2006 Ford F-350
bubbaf250 is starting off with a positive reputation.
Post Recommend Diagnosis Shop in Denver area
You should try posting this query in the Explorer forum. There might be people who know more about technical details of the Explorers on that forum.
http://www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID107&conf=DCConf ID9
Good luck.
__________________
2006 F350 4x4 XLT, CCSB, 6.0L/5R110W
1980 F250 4x4 Custom, 351M/NP435/NP208/D44HD-TTB/D60-FF
  #5 (permalink)
Old 12-28-2002, 01:50 PM
kspilkinton's Avatar
kspilkinton kspilkinton is offline
kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.kspilkinton has a very good reputation on FTE.
You also may look in the area of the tranny... all of the conditions you described could be attributed to parts in the automatic.
-Kerry
  #6 (permalink)
Old 12-30-2002, 11:31 AM
Paarrothead - I'll go ahead and check the voltage of my battery, I do think it is a little low. At night with the headlights, foglights and the stock radio on, the lights do go dim sometimes when I'm at a stop light. Both Ford dealers performed cat. efficiency tests, which both came out normal. I don't know exactly what these tests include, but I think it would be all computerized. All of the shops I have taken it to have scanned for codes. Only time I came up with a code was when the CEL was on for the bad #4 plug. Clear ever since.
BubbaF250 - I have had an ongoing post in the Explorer forum, which I have received some excellent advice. Unfortunately nothing suggested has worked.
kspilkinton - I'm starting to believe it is something with the Tranny, since I've found so many problems with the 4R70W. Ford thinks it's okay though. This is why I'm looking for another shop. Ford says thay can't find anything wrong with it, but there is.
Thanks everyone!
__________________
Justin
  #7 (permalink)
Old 10-06-2004, 09:17 PM
fordtough4x4 fordtough4x4 is offline
fordtough4x4 is starting off with a positive reputation.
possible help
i have a 91 150 5.0 fuel inj. similar problem replaced throttle possition sensor cured my problem good luck
Tags
denver, ford, shops
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
