cylinder location - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
cylinder location
Old 10-16-2009, 07:57 PM
kerim1 kerim1 is offline
kerim1 is starting off with a positive reputation.
cylinder location
hi i have a code on my 2000 expedition and it says PO301 missfire on cylinder #1 i would like to know if anyone has a diagram on the location of the cylinders.
Old 10-16-2009, 08:02 PM
madsonp's Avatar
madsonp madsonp is offline
madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.madsonp has a good reputation on FTE.
Old 10-16-2009, 08:06 PM
thank you for your help
Old 10-17-2009, 03:42 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
To this day I am still baffled over firing orders with no distinct pattern.
Old 10-17-2009, 07:53 PM
Mark62's Avatar
Mark62 Mark62 is offline
Mark62 is starting off with a positive reputation.
Atleast #1 is easy to replace the Coil...
I have repalced 4,2,3 in that order since I got mine.
Old 10-17-2009, 08:03 PM
i got my missfire fixed today turned out that the coil was bad.
thanks for all your help
Anybody have a source for.... Rust Wrangler 1947 and Older Ford Trucks 5 02-21-2016 01:22 PM
2007 E450 Van, P2196 OBD Code Tomthumb47 1968-2013 Full Size Vans 6 12-15-2014 08:27 AM
'Factory' location of proportioning valve? alchemist1 1973 - 1979 F-100 & Larger F-Series Trucks 11 10-02-2012 10:31 AM
2007 4.6L #8 cylinder misfire hunt1moore Modular V8 (4.6L, 5.4L) 4 09-01-2011 07:38 AM
Cylinder #5 m.pastorelle Escape & Escape Hybrid 2 11-28-2010 09:23 AM
Tags
54, 60, 9n, coil, cylinder, diagram, e350, engine, expedition, f250, ford, location, numbers, order, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
