How do you start your truck?
Old 10-14-2009, 11:55 PM
yankeerebel's Avatar
yankeerebel
yankeerebel is offline
I've noticed that as the weather has gotten cold, my carb won't stay on fast idle. I pump the gas once and the engine (351M) will crank and die in about 1-2 seconds. I'll do this 3 times until it 'catches' on fast idle. Some say only pump the gas once. I've always done it 2-3 times. I had an old Chevy(sorry) and I used to pump it 5-10 times to get it to start. Should I be holding the gas down at all when I engage the starter?
Old 10-15-2009, 12:07 AM
Vinford's Avatar
Vinford
Vinford is offline
Pump 2 or 3 times and turn the key is what gets mine going.
Old 10-15-2009, 12:26 AM
Hmann's Avatar
Hmann
Hmann is offline
pump gas 2-3 times turn key wait a second then hit the gas hard once to keep it going. let it warm up and go...
Old 10-15-2009, 07:36 AM
jlj6t's Avatar
jlj6t
jlj6t is offline
Same here...pump it a few times and hit it. Usually followed by a long "warm-up" period to let the "mellow" Flowmasters gently stir the neighbors.
Old 10-15-2009, 07:58 AM
moose4x4's Avatar
moose4x4
moose4x4 is offline
Check your choke linkage, make sure it is free, it might be taking 2-3 times before the choke closes and sets fast idle. You can usually free up linkage if it is stiff by spraying and working linkage with carb cleaner. Burce
Old 10-15-2009, 09:57 AM
i-w's Avatar
i-w
i-w is offline
i gently rub the top of the dash in a clockwise circular motion. pump the
gas 3 times, say a prayor and stare at the cross that is hanging from the
rear view as i turn the key. i dont know what you are all doing. but it works
for me.
Old 10-15-2009, 12:18 PM
Jermafenser's Avatar
Jermafenser
Jermafenser is offline
If the carburetor is tuned properly, no pumping is needed.
I depress the accelerator pedal slowly, then slowly let it back up then start.
Old 10-15-2009, 12:58 PM
OrangeJuice's Avatar
OrangeJuice
OrangeJuice is offline
For me I turn the key to the on position and slowly press the gas pedal to the floor once, release the pedal, turn the key and it fires right up and holds idle.
OJ
Old 10-15-2009, 01:08 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
Depress accelerator pedal, set choke (manual), let accelerator pedal up 3/4 of the way, hit key and let it fast idle until motor reaches operating temp.
Old 10-15-2009, 01:39 PM
CrazyAirman's Avatar
CrazyAirman
CrazyAirman is offline
Push to floor, let up, and starts instantly. stab pedal after 10 seconds or so, comes down to the next lower setting, and I can drive away.
Warm, I dont even touch pedal, just hit the key and again, its pretty instant.
But my Holley is tuned/choke adjusted perfect, and the MSD setup helps too
Old 10-15-2009, 02:52 PM
ford to the bone's Avatar
ford to the bone
ford to the bone is offline
ford to the bone
i pump mine 2or3 times then it starts
Old 10-15-2009, 07:59 PM
93F22A6's Avatar
93F22A6
93F22A6 is offline
Pump it 2-3 times, pull the chock and turn the key. Usually does it but it hasn't been to cold where I'm at yet.
Old 10-15-2009, 08:56 PM
Don S.'s Avatar
Don S.
Don S. is offline
Push pedal to the floor, and let up. Then turn the key, if it doesn't start the first time once or twice more with the starter and it starts. Usually catches the first time.
Old 10-15-2009, 09:19 PM
pidaster's Avatar
pidaster
pidaster is offline
Should I have to press the pedal with my Edelbrock carb with electric choke?
Old 10-16-2009, 02:10 AM
Jermafenser
Yes. You always press down with a carbureted engine. This is to set the fast idle on a cold engine.
