wheel bearing assembly replacement how to?
From this forum's Tech Folder ..... a guide to replacing balljoints (you have to remove the wheel bearing assy to get to the ball joints .... https://www.ford-trucks.com/forums/3...ll-joints.html
Hope this helps.
Hope this helps.
They are not bad to do but if your stripping everything down and this is a 4x4 time to replace the front U joints if they haven't been done.
Murphys law you get it all together and a week later the front U joints on the axle start squeeking.
Good time to change brake rotors and do the brakes. If the ball joints have play might aswell do them too.
May sound expensive but it is easier to do it now than later.
Get your crying towel out the unit bearings are not cheap
on
Thanks guys, here is the deal. We just bought a 01 excursion 7.3 4x4 with 114000 miles. It needs the left wheel bearing, right upper ball joint, but will replace bottom also, both locking hub assemblies, the pads are about 1/3 left but the rotors look good so probably just a light resurfacing and the rear pinion is leaking. This is our first superduty style rig so just trying to get all the correct procedures before I start. The dealer bought the wheel bearing assembly, which was $321 and that is with 20% off. I think I can get the hub assemblies for around $100, ball joints will probably be about $100 also. Hopefully the bearing assembly is the correct one.
Headviking
09-02-2014 06:44 PM
RedTaurus94
12-30-2013 10:01 PM
