wheel bearing assembly replacement how to? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 10-16-2009, 05:17 PM
wildstang's Avatar
wildstang wildstang is offline
VT Chapter Ldr
wildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputationwildstang has a superb reputation
Does anyone have a link on how to replace a wheel bearing assembly, this is on a 01 excursion 7.3L. Thanks for any help.
Old 10-16-2009, 05:57 PM
ironmine ironmine is offline
ironmine is starting off with a positive reputation.
From this forum's Tech Folder ..... a guide to replacing balljoints (you have to remove the wheel bearing assy to get to the ball joints .... http://www.ford-trucks.com/forums/35...ll-joints.html
Hope this helps.
Old 10-16-2009, 09:09 PM
TexasRebel's Avatar
TexasRebel TexasRebel is offline
TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.TexasRebel has a great reputation on FTE.
4x4 or 4x2
front or rear?
Old 10-16-2009, 11:41 PM
Meeks's Avatar
Meeks Meeks is offline
Meeks is starting off with a positive reputation.
Hey man when I changed mine on my 01 F250 there was two diff ones. The difference was the studs. They were different sizes. Think one was metric and one was standard.
Hate for you to have to take it back off. Not to hard of a job though.
Old 10-17-2009, 03:08 AM
Kenworth Kenworth is offline
Kenworth is gaining momentum as a positive member of FTE.
They are not bad to do but if your stripping everything down and this is a 4x4 time to replace the front U joints if they haven't been done.
Murphys law you get it all together and a week later the front U joints on the axle start squeeking.
Good time to change brake rotors and do the brakes. If the ball joints have play might aswell do them too.
May sound expensive but it is easier to do it now than later.
Get your crying towel out the unit bearings are not cheap
Old 10-17-2009, 09:28 AM
holbs10 holbs10 is offline
holbs10 is starting off with a positive reputation.
Good tips here. How much you talkin for the bearing assemblys? And how do you know when you should change out you bearings.?
Old 10-17-2009, 02:20 PM
I haven't had to buy one yet but I heard they are around 500 each
You can't tell when a unit bearing is about to go because you can't inspect the bearings
The days when you had separate wheelbearings you could inspect them.
Even class 8 trucks are using these unit bearing assemblies.
Old 10-17-2009, 10:15 PM
wildstang's Avatar
VT Chapter Ldr
Thanks guys, here is the deal. We just bought a 01 excursion 7.3 4x4 with 114000 miles. It needs the left wheel bearing, right upper ball joint, but will replace bottom also, both locking hub assemblies, the pads are about 1/3 left but the rotors look good so probably just a light resurfacing and the rear pinion is leaking. This is our first superduty style rig so just trying to get all the correct procedures before I start. The dealer bought the wheel bearing assembly, which was $321 and that is with 20% off. I think I can get the hub assemblies for around $100, ball joints will probably be about $100 also. Hopefully the bearing assembly is the correct one.
Old 10-18-2009, 01:00 AM
EXv10 EXv10 is offline
EXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputationEXv10 has a superb reputation
The 01 takes the coarse thread studs. You can grease those hubs through the abs hole also. No need to resurface the rotors. Make sure the pinion is tight with a slight drag on it.
Old 10-19-2009, 10:45 AM
Quote:
How do you grease the bearing through the abs hole.
Throw out bearing ige1963 1961 - 1966 F-100 & Larger F-Series Trucks 3 01-03-2015 03:41 AM
How to replace a front wheel bearing hub assembly Headviking 6.0L Power Stroke Diesel 15 09-02-2014 07:44 PM
Replacing front wheel bearings RedTaurus94 Explorer, Sport Trac, Mountaineer & Aviator 1 12-30-2013 11:01 PM
Front Wheel Bearing assembly Johnny Bravo 45 1999 to 2016 Super Duty 4 08-03-2010 10:35 PM
Hub Assembly Bearing kbarger1 Excursion - King of SUVs 10 04-11-2007 01:06 PM
Tags
4x4, assembly, bearing, cab, change, crew, diesel, duty, ford, replace, specifications, super, trucks, unit, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
