Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-16-2009, 11:31 AM
fetchitfido fetchitfido is offline
fetchitfido is starting off with a positive reputation.
plastic side gas tank sending unit removal
Any tricks/tools to get the plastic screw on cap off? I can't get it to budge. It's leaking somewhere on the outside of it and I fixed it when it was warmer out with JB weld. Then I mostly fixed the exhaust, with it dumping right at it. Now the JB's gone and melted away and it's too cold to put new stuff on.
If I can get it off I'd kinda like to replace it as the fuel gauge doesn't work but I dunno if it'd even fix it as the ammeter and water temp gauges don't work (only speedometer). Oil pressure gauge sending unit is MIA so I kinda know why that gauge doesn't work. I've only found a new sending unit on LMC, and maybe advance auto but for $50 I'd rather just guess at how much is in the tank.
Any idea's on getting it off/out without dropping the tank and/or shield?
  #2 (permalink)
Old 10-31-2009, 03:48 PM
Got it out, had to drop the tank with ~8 gallons of fuel still in it. Now it's all fubar and Napa only lists sending units for the rustable rear tank. I beat out the sending unit from the "holy" rear tank in the bed , they appear to be the same part just with different bends.
Can I get a sending unit for the rear tank, bend the line to the right shape and put it in? At this point I don't really give a hoot if the fuel gauge works (none of the others do...) but it'd be nice if it does.
__________________
1978 F250 4x4 4spd
400m
Holley 4bbl 4160 w/ manual choke
Elderbrock Performer Intake
mostly bald 33's
Tags
1979 , 2006 , f150 , fix , foford , ford , fuel , gas , plastic , removal , sending , tank , tanks , truck , unit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
